Wheel Spacers
Old Mar 8, 2005
Leets's Avatar
Leets is an unknown quantity at this point
Wheel Spacers
Just curious if anyone on here has put on some wheel spacers. I'm curious at what size I'll have to replace the bolts on the 7th gen. I'm also curious how easy it is to switch out the bolts on the front hubs. If there as much fun as the older style then I'll just pass. Any info/opinion is greatly appreciated. Thanks.
Old Mar 8, 2005
danscreations's Avatar
Tuckin' 19's
danscreations is an unknown quantity at this point
Anything else other than 3mm spacer you really need to get longer studs. I was ****in around one day and put 6mm (1/4in) spacers on th rear to see what it would look like. Cleared fine dropped around 3" w/19's w/trimmed rear lips. However, I would have never ran them with out changing the studs as I only got around 3 full turns.
Old Mar 8, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
what kind of spacers did you use? link?
Old Mar 9, 2005
Leets's Avatar
What's involved in changing the bolts? Are they easily removable without disassembling the hub?
Old Mar 9, 2005
btuner's Avatar
btuner is an unknown quantity at this point
i always wanted to do that but was never sure on what size i should go with
Old Mar 10, 2005
Tuckin' 19's
You will need to remove the rear drum (easy as its the same procedure as changing the rear shoes). Take them to a place that has a press and press them out. Then press in the new ones. Go back and install. EASY! ARP sells new studs there cheap!
Old Mar 11, 2005
R1Style's Avatar
I ran 8mm spacers with my gsr blades and I was fine. I could have used longer studs but didn't get around to buying any.
Anyways, the only company that make hubcentric spacers that fit our car is H&R. Depending on what kit you get they come with longer studs to so it's a simple bolt on kit.... the only thing is price. They are fvcking expensive as hell.
Old Mar 11, 2005
Leets's Avatar
I was looking at the Eibach 5mm spacers. Any thoughts on these?
Old May 16, 2005
eye_see_you's Avatar
let the devil out
i'm looking at these due to my new brakes .. anyone tried it ?
nirvanaguy
25
Oct 26, 2017 07:26 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
rainman15
Sep 6, 2015 11:10 AM
