proper break fluid flushing Anyone????
Old Mar 6, 2005
dubz01si's Avatar
dubz01si is an unknown quantity at this point
how can i do this on my own ???
Old Mar 6, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
1. get something to suck out the fluid from the master cylinder reservoir. (i.e. plastic syrenge ?Sp, or even a turkey baster.)
2. fill it up with the new brake fluid.
3. bleed brakes a couple of times until new fluid comes out of each bleeder on each brake.
dont try and bleed out the remaining old fluid after sucking out the fluid from the reservoir. if you do, your going to have to pull out the master cylinder and bench bleed it. just do it my way by using the new fluid to push out and bleed out the old fluid and youll be fine.
Old Mar 6, 2005
flotsamm's Avatar
You can, you just have to buy a brake bleeding kit. I bought one a few years ago from MityVac for like 35 bucks. Its a little hand pump that you connect up to your bleed fittings and pump out the old fluid until it comes out clean. Just gotta make sure the reserviors never go dry.
Old Mar 6, 2005
dubz01si's Avatar
thats easy enough!
the level is seem's low i hope i dont have a leak in the rear cylinder's
Old Mar 6, 2005
or you can do that as well, and like flotsamm said, if it goes dry, youll have to bleed the master cylinder as well.
Old Mar 6, 2005
dubz01si's Avatar
okay! when i bleed them how do i do the order.. Rear to Front Right ?
Old Mar 6, 2005
flotsamm's Avatar
I always thought you bleed from the furthest wheel first, but I recall reading that there was some other order also... I dont remember where I read that.
Old Mar 6, 2005
dubz01si's Avatar
**** i know what your talking about i just dont know 100%
Old Mar 6, 2005
tacheon's Avatar
tacheon is on a distinguished road
Correct bleed sequence is Fr. Left, Fr. Right, R. Right, R. Left. This is directly out of the service manual. No need to curse people.
Old Mar 6, 2005
dubz01si's Avatar
thanks tacheon
jzhartman
22
Jul 23, 2015 10:42 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
Causemo
Jul 4, 2015 07:11 AM
