Broken wheel stud...
Old Feb 18, 2005
silverrazor's Avatar
silverrazor is an unknown quantity at this point
Unhappy Broken wheel stud...
I was taking my wheels off to replace my front brake pads and realized that one lug nut was extremely difficult to remove, actually damn near impossible. So after unsuccessfully trying to torque it with a make-shift lever, I quit, hoping an air tool would do the job. My buddy used his 500lb air tool and surely it came loose...along with the broken stud!!!!
Is replacing the front wheel stud for a 2001 Civic coupe something that I can do myself or is should I bring it into a shop? Also, how much should I expect to pay?
Thanks!
Old Feb 18, 2005
streetglower's Avatar
Thanks!
well unless you have access to a press, then you need to take it to a shop. You have to remove the knuckle and hub assembly and press them apart to remove it. A shop charged me $70 in labor to replace one on the front.
Old Feb 19, 2005
Damn! For a freakn' screw! Oh, well...such is life
Thanks for the info.
Old Feb 19, 2005
IrockCivics's Avatar
I'm missin 2 of them in the right side the front and back tires, will that mess up anything driving like that?
Old Feb 19, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
2 on each wheel?? If so, that is a problem. Running around with one missing temporarily is not as big of deal. We replace the front studs on most cars with slide off rotors for around $40 or so. We can change a front stud in a matter of 15 to 20 minutes usually.
Old Feb 19, 2005
muzhik's Avatar
where ghetto dogs come for the lowdown on deals...
muzhik will become famous soon enoughmuzhik will become famous soon enough
my dad has 01 camry, he broke 2 or 3 studs on rear drum, I bought new studs at schuks and he replaced it himself.. dunno bout the civics...
Old Feb 19, 2005
on the newer civics, you have to pull off the knuckle and hub assembly and press them apart in order to replace the wheel stud. It doesnt take 15-20 min. You can take off the rotor, but you will see that you cant knock the stud through, you have less then a millimeter or so of room to work with.
Now on the rear, you can take the drum off and knock the wheel stud out.
Old Feb 19, 2005
Roy's Avatar
Roy
Roy is an unknown quantity at this point
you can get a slide hammer and pull the hub off the knuckle with out taking anything else off. i have extra studs that came with my H&R wheel spacers that i don't need. do you want them? it's a set of 8.
Old Feb 19, 2005
VTECTypeR's Avatar
My friends shop did it free for me
Old Feb 19, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
so its not a simple "hammer a new stud in from the raear" job?
Old Feb 20, 2005
VTECTypeR's Avatar
Wells its pretty simple if you have the tools. Like Roy said you need the slide hammer and what you do is connect it to your remaining studs and screw it on. Then you give it a couple hard wacks and the hub should come off.
Old Feb 20, 2005
LiKEaFeRiO's Avatar
Yeah its really not a simple remove and replace proceedure.
I got my front replaced for $40 and the guy gave up and took the hub off.
You do need a press to remove it.
Old Feb 20, 2005
correct. The rear you can do easy, but not the front.
muniorbust
33
Aug 31, 2015 08:59 PM
mishima
Aug 22, 2015 06:32 PM
alaga
25
Aug 13, 2015 04:42 PM
mrwhos
Aug 11, 2015 02:03 AM
glockma630
Aug 1, 2015 10:30 AM
