Hub assembly....
Old Feb 11, 2005
Seabass's Avatar
Seabass is an unknown quantity at this point
Hub assembly....
Hey everyone, ok to make a long story short I ended up hitting the hub assembly too many times when installing a new axle and its now deformed and i need to get a new one, can you get just the hub assembly and put it onto the knuckle i already have, or do i have to buy a whole new knukle/hub assembly? On honda automotive parts.com, the knuckle isnt a part of the hub asssembly so im thinking you can install a new one, but i could be wrong, anyone know? thanks.
Old Feb 11, 2005
Seabass's Avatar
anyone?
Old Feb 11, 2005
streetglower's Avatar
yes you can just buy a new hub. Just need to buy new wheel studs to be pressed in because the new hub doesnt come with wheel studs in them.
Old Feb 11, 2005
Seabass's Avatar
how do i install the new hub?
Old Feb 11, 2005
you have to remove the knuckle from the old hub. It needs to be pressed apart.
Old Feb 11, 2005
Seabass's Avatar
So im guessing at a shop...how much do you think that would cost? Thanks.
Old Feb 11, 2005
I dont know.
Old Feb 12, 2005
tfnaaf's Avatar
BLDNPSI Mod
you will most likely end up replacing the bearing too
califcamper
Suspension
Apr 11, 2016 03:43 PM
danace99
Oct 17, 2015 02:51 PM
siliconvalley
Sep 15, 2015 09:48 PM
Strycker
Aug 18, 2015 02:25 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
