Wilwood Big Brake Upgrade!
#31
ThE FaMiLy SeDaN
Rep Power: 0 front two.. unfortunately you folks cannot get them for that price.. thats wholesale.. see i dont like it when my friend dan tells people wholesale cause then everyone wants em for wholesale
stachmo... walk to the back of your car we have drums.. its for front only... also... dans selling his for 575+shipp so id get on that asap... cause new will run you like alot more
#34
BLDNPSI Mod
Originally Posted by Roy
if you take into account the coefficient of factor per square inch, the total friction factor of the unit has increase. the total force applied to the rotational system has increased. more stopping power and a shorter distance.
Originally Posted by Zzyzx
You still run in to the issue that the tire can only apply so much torque to the ground before it brakes free. Increasing the torque the brakes can exert on the tires simply means that you'll reach that Terminal point with less Pedal travel.
Both Zzyzx and Roy are correct. The larger rotor CAN decrease stopping distances and increase braking performance(pedal feel and effort). But it still comes down to the car can only stop at a rate that the tires will allow with out skidding.
#40
Rep Power: 0 You can, but you need Si parts hub/spindle, caliper, flex lines, e-brake cable from RSX.
Then you could have bought the AEM big rotor upgrade for the rear, but the brake division is now owned by Power Slot rotors and they want like twice what the rotors are actually worth retail, so imo not worth it, unless you got money to burn, better off with OEM rear rotors if you do the conversion.
Causemo
07-05-2015 06:42 AM
Supramk3
06-11-2015 11:13 AM
