who has successfully installed a rear sway bar ona LX(that didnt come w/ one)
ThE FaMiLy SeDaN
if you have succesfully installed a rear sway bar on a LX that didnt come w/ one please contact me... i reallllly want one.. but i dont wanna ghetto weld it and etc... lemme know what u did and if ur local and u help me out. there will be rewards in it for you..
i want some damn oversteer... i know once i get my tein i can dial rear out stiffer.. but ive heard sway bars work wonders...i dont have one,.. i wouldnt know
ThE FaMiLy SeDaN
yes i did senor search king.lol
im trying to find someone like a person who doesnt know much that did it..
this should be in susp forum sorry move me..
u can use EX sway but: you need to make soe brackettes and then weld them onto rear control arms.. yeah alot of work.. or buy EX control arms=more work..
so ina nut shell im trying to find people other than grey... who did the swap and how they did it because maybe if i can find the one guy who got brackettes made he can get more made.. and maybe if hes somewhat near me.. i can have his shop weld them..
riley
riley
PC Tech / Autocrosser
riley
riley
1: Either fabricate your own and have them welded, or... (will need a way to mount the bushings to the sub frame)
2: buy the lower control arms you need with the brackets already on...(will still need a way to mount the bushings to the sub frame)
3: (the best option) Look into buying a progress mounting kit that has the brackets you need that are adjustable since the use a U bolt to hold them on. Only other thing you need is a way to mount the bushings on the sub frame on the rear if you don't have those holes already, in which case you want to buy the progress rear sway and tie bar that way you will have all you need to install it. The whole thing can be bought for around $250 if you order from the right websites. (this is the option I am going to select after getting seasoned in driving my car the way it is @ autocross events).
This is coming from someone that has looked into doing the install that has average to above average knowledge about cars. You and a friend should be able to accomplish the install on a weekend, weather providing, in a few hours.
I need TP for my bunghole
riley
riley
Her use 1/4 inch steel and used a coke can to make the correct cuts for the braket to seat. the coke can is the same size as the tube for the rear control arms the guy said.
I'll try and find the post.
ThE FaMiLy SeDaN
i saw that post im not gonna "make" brackettes tho.. the progress kit comes w/ U brackettes so u dont have to make a mounting point in control arm?
just verifying
just verifying
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
