big rotor/brake question
Old Jan 30, 2005
WannaBFast's Avatar
Prowlin' with a Purpose
i read somewhere that it would throw off the abs sensor.. is this true? given the design of the whole setup i doubt it would because it is all run off of the axels... wanna shed some light on this?
Old Jan 30, 2005
tacheon's Avatar
tacheon is on a distinguished road
Short answer. Yes it can mess up your abs function. Not because it affects the sensor directly, but because everything works as an integrated system. The parameters of slave cylinder volume, braking force, tire size, etc were programmed into the abs computer with default oem components. So if you go out and change something like a caliper and rotor, the abs computer isn't going to "know", teleologically speaking. For an in depth look at this matter, see the link below.
http://www.stoptech.com/whitepapers/...ake_122701.htm
Old Jan 30, 2005
Zzyzx's Avatar
Autocross Junky
Its possilbe, as noted in the article above... there is also the issue of possibly altering the brake bias unfavorably....
Old Jan 31, 2005
WannaBFast's Avatar
most kits ive seen just move the brake caliper outwards.. and there isnt a larger more powerful caliper with it..
Old Jan 31, 2005
Zzyzx's Avatar
Autocross Junky
Yes, but by moving the caliper farther from the center of rotation you are effectivly increasing the amount of Torque that can be applied to the tire/ground interface.... Meaning you have increased front Brake bias. (it also means that it will take less brake preasure to lock the front brakes then it use to.... Which can lead to ABS problems).
Old Jan 31, 2005
orso's Avatar
orso is an unknown quantity at this point
everything they said is true and i know because i have larger rotors. the only time it is really a problem is when you are driving like a mad man in slick conditions. other than that i don't have any problems.
7thgensurvivor
Aug 26, 2015 06:17 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
NoobyKid
Jul 13, 2015 07:53 AM
aultman1990
Jul 9, 2015 08:27 PM
