Will any Acura or Honda OEM wheels from other cars fit?
Old Jan 14, 2005
ccajun4real's Avatar
ccajun4real is an unknown quantity at this point
I am about to put some 16" RSX wheels on my CR-V and wanted to know if there are any other Acura or Honda OEM 16" or 17" wheels that will fit my 2002 EX? I have a buddy that works at a dealership and they get some left at the shop and things like that so may be able to pick them up cheap. Thanks for the help
Cajun
Old Jan 14, 2005
TeLLy's Avatar
Yes, it's an Acura EL
RSX are 5x114 right? In which case, I think Prelude and the 5-bolt Accord rims will fit. And I think just about all Acuras except the EL are 5x114 as well...I don't know about offset, I'm just talking in terms of bolt pattern.
**EDIT** sheeit I read the question again, and if i get this right you're looking for rims for your CIVIC and not your CRV. Obviously any Civic (except type R) rims should fit, including the 4-bolt EP3 rims (02-03?). As well, Acura EL, any Integras except ITR....
Old Jan 14, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Most of the honda specs are the same across the bolt patterns. As long as the dimensions are the same, you probably can do it (the optional 18x8 TL wheels prolly won't fit, but who knows) but RSX wheels should fit a CRV. You probably could also use S2000 front wheels (make sure you get 4 fronts), TL, CL, etc.... probably would fit. If you got a dealer buddy... why not just try test fitting them.
I'm assuming you want this for your CRV. If its for your Civic, then you should have read the FAQ and I'm locking this.
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
mugenca
Apr 16, 2015 12:15 AM
