spoon calipers
spoon calipers
would anyone know where i would beable to get a set of spoon calipers.
i tried the website, but it doesn't list the honda civic 01 to 04..
i found a guy on this website that has it on his car
i just want to know his application
Originally Posted by TeLLy
I think the EP3 application should do ya, at least for the fronts.
Either that, or he just bought the calipers by themselves and had a bracket made for them... which is a possibility. Thats Robinyip's car right?
El Pinche Turbo Mexicano
well suposedly this site says that Typeones fit, and they are the same number, so maybe they thought that since almost all Type R stuff fits these would to
http://www.hondawerx.com/Spoon/brakes.htm
^^Yeah it says ep3 civic and then says ep3 civic type-r, so I'm pretty sure both fit.. I'm planning on doing the complete si disk brake swap and then do the spoon fronts =)
This is in Canada, but AJ is the North American distributor
http://www.aj-racing.com/spoon-sport...=EP&type=Brake
personally, it's not worth it if u ask me...they're pretty expensive...
secondly, the universal one's will fit our cars (s2000 calipers)....u'll need to get custom brackets made to hold the caliper, and if the brake pads are too big for the rotor, u might have to trim some of the padding off ur pads....
my friend has spoon calipers on the front of his prelude...and there's no listing for a prelude on the product list for spoon....
I just like em cuz they're spoon, i spend way to much money on authentic products lol
Originally Posted by 18inchpride
here ya all go!
Sounds expensive seeing as how you can buy an entire (set of four) Brembo big brake kit (to include calipers and rotors) for about $3500.
Originally Posted by rijowysock
i can get a full set of jdm DC5 brembo 4 pot frot 2 pot rear, rear type R control arms and front type R arms.... brembo rotors.. all for 1400..lines and all
The thing that I don't like about Spoon calipers is that they still utilize a stock sized rotor. One of the biggest benefits of a BBK is the fact that you get less heat fade...
It's still a good setup though.
Hmmm, so if I got these they'd go on the fornt no prob... but I woder if they work on the back also... hmmmm (has civic si rear sics in back)
Autocross Junky
and their biggest draw back would be the increase in rotational Inerta = Slower acceleration.
For performance, Big Brake kits are more of a last resort thing... meaning you increase the size of the rotor only after you've tryed every thing else to keep brake temps down (Higher temp pads, Better Vented Rotors, Brake Ducts, High Temp Brake Fluid, ect ect....)
Thats probably why Spoon still uses stock sized rotors... Because they don't want to make you slower.
Junquito89
Sep 27, 2015 10:22 PM
