is there such a thing as overtorque(ing)?
Old Dec 17, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Yea, just as the title says. Is it bad to overtorque bolts, like the ones on the rotors?
Old Dec 17, 2004
jttegx's Avatar
OMNES AD UNUM
i think ive over torqued the lugs on my wheels but i've never had a problem ever since i been doing it. so its fine to me but im guessing it'd be better to have them torqued to the correct setting?
Old Dec 17, 2004
CapYoda's Avatar
Escaped Convict
80 lb.ft on the lung nuts.
yeah its bad. i mean for stuff like lung nuts, u probably wont have much issues.. but most bolts and nuts have torque settings for a reason.
so u wont snap/strip/worn/tear/etc.etc. the bolt when u try to take off an overtorqued nut.. vice versa.
this is one of my pet peeve.. I HATE it when I get my car back from a shop/dealer.. and when I have to work on my car and take off the wheels for whatever reason.. it takes super leverage just to get the lung nuts off.. because some fool with an impact wrench doesnt understand torque setting.
i've seen morons at shop that doesnt know there's such thing.. and just goes NUTS with those impact wrench.
torque wrench exist for a reason. the same goes for torque specs.
Old Dec 17, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well try not to over torque the lug nuts.. ive seen wheel studs snap before... its not fun
Old Dec 17, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
If you over torque them to often you stretch the stud and eventually you will strip the lug nut on the stud and the only way off is going to be the stud breaking off with the lug. Especially if you live somewhere were things rust. It will happen ever easier. I know from experience.
Old Dec 17, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
actually most warped rotors are the result of extreme torque
Old Dec 17, 2004
cvayala's Avatar
cvayala is an unknown quantity at this point
I'll try to keep this story short.
2 lugs sheared off on one of my mercedes wheels, that can't be good. I went and bought a torque wrench found all the lugs were too tight. I sheared another one as I was trying to remove it. Now they are all good.
Next, I go to the Civic, first lug I'm trying to remove, I shear the 3/8" drive extension I'm using, finally got the lug loose then torqued it to spec.
Yeah, I would say overtorquing is bad.
--Carlos
Old Dec 17, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
1 thing I would definately recommend to have the proper torque specs is installing pullies
Old Dec 17, 2004
scatman's Avatar
Still in the game...
overtorqueing= breaking the head off a bolt and the stud is stuck inside wherever you were tightening it.
Old Dec 17, 2004
streetglower's Avatar
Do not overtorque anything. I have replaced about 10 wheel studs so far from being overtorqued, also causing one set of warped rotors. And now I need a new oil pan because of me overtightening my drain bolt.
Misfit2613
Jul 30, 2015 09:49 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
robbie374
Jul 7, 2015 02:56 AM
