Bleeding Brakes
Old Dec 10, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Bleeding Brakes
Ok, i've got new rotors, pads and fluid on its way. for the last hour and a half i've been reading up on brake stuff. And i still got a few ?'s. First: i'm going to be replacing the brake fluid so i've got to flush the whole system. inorder to to this do, i suck out all of the old fluid in the MC and then start the bleeding process? or suck out all the old fluid and then put new fluid in, then start the bleeding process? if i do it the second way, won't the new and old fluid mix together? is that ok? thanks guys
Old Dec 10, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
You will get less air in the system if you just pour the new in and bleed each wheel until you see the new stuff.
It is harder to remove air from the master cylinder than it is to just pump a little fluid past that point.
Plus the thinking is a little old fluid is a lot better than a little new air.
Besides flushing from the master cylinder out will all but push out the old.
Old Dec 10, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
That Pretty Much Says It All !!!
I've recently have done mine, took pictures and have been to lazy to post up a DIY.
You really do want to avoid getting air in the brake lines at all cost. Having two people for this job really helps.
If you have any other Q's let us know.
BTW have at least 2 or 3 quarts of Brake fluid, you can never flush too much, and it's cheap. I just bought a half gallon, I think I used about 2 quarts
Old Dec 10, 2004
Shlomo's Avatar
thanks for the info, i'll keep you posted
Old Dec 10, 2004
dru106's Avatar
ThE CoRRupToR
u need 2 ppl to do this!!!
1st add fluid to the top...
pump brakes 3-4 times and hold
have someone open the bleeder valve
pedal should reach to the floor and fluid should come out
close bleeder valve and repeat till u see no air or dirty fluid comin out. And make sure u check the resovior level when u bleed em. Also when u bleed em make sure u close the cap.....
Old Dec 10, 2004
Shlomo's Avatar
it seems so easy to do, i guess i'll just find out as i do it. yeah, i'm going to get a lot of brake fluid just incase
Old Dec 11, 2004
Shlomo's Avatar
hey guys, just out of curiosity, how much brake fluid is actually used(contained) in the MC and lines combined?
Old Dec 11, 2004
4jacks's Avatar
i dont actually have the specs but i used about 3 quarts , the dealer might have a number
Old Dec 11, 2004
Shlomo's Avatar
used 3 quarts to flush/bleed it or 3 quarts were put in? how quarts are in a liter?
Old Dec 12, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
i did my whole system with like half of a liter
Old Dec 12, 2004
Shlomo's Avatar
ok, cool
Mad Dog Tannen
Sep 12, 2015 12:48 AM
thaler4cuse
Sep 7, 2015 08:25 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
