205/45/17
Probably near 20k if you have good camber. That's how much I get. Also depends on the tire your getting because softer tires will wear down much faster, but better grip.
so your pretty much worrying about threadwear over handling/performance. www.vulcantire.com has falkens for cheap. when looking at an tire, read the threadwear rating... higher the better.
www.tirerack.com www.1010tires.com <---- they have basics about tires. what you should know etc etc.
if your lowered, a camber kit (front is unnesscessary..well for me) can save your tire life. im pretty sure you know what negative camber is.. if not, just say so.
I Queef > You
No, its gotta be more than 20K. I have Kumho Ecsta Supra 205/40/17 on my car right now. So far I've hit 24K and only the insides were wearing out b/c I set my camber -.5 in the rear, so I flipped the tires inside out, so I should get abou another 24K on them. I'm pretty much a granny driver, but I take corners fast thats all.
civic12
Feb 24, 2004 05:38 PM
eskimo
Aug 26, 2002 02:32 AM
