Brake Upgrade
Old Jul 30, 2004
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
Brake Upgrade
Ok i have a turbo and my car is alot faster but that means i get up into the 100's alot fast so when the light turns red i havto stop and im usualy on the brakes HARD, and one time they started smoking like crazy. so my question is i want some advice on a good brake upgrade. and my bigest paroblem is brake fade. so if you have done an upgrade let me know. and the rear disc conversion really helps.
Old Jul 30, 2004
Mr.Modify's Avatar
you got rims? what size? big brake kits....ever thought about those? search to for "REAR DISC CONVERSION" it's been done on here.
Old Jul 30, 2004
Mr.Modify's Avatar
Some Facts about the conversion
http://www.7thgencivic.com/forums/sh...isc+Conversion
Lots of threads in here about the Disc
http://www.7thgencivic.com/forums/se...1&pp=25&page=1
Old Jul 30, 2004
Zzyzx's Avatar
Autocross Junky
1st step, upgrade your pads to a higher temp pad. (No point going getting a big brake kit if you dont NEED it, and besides Biger rotors = more rotational inertia = slower acceleration). That should clear up your brake fade problem.
after that it would probably be a good Idea to get some High Temp Brake fluid. ATE Super blue or Type 200 would be a good choice.
Finally, you may want to look at some slotted rotors (They wont make you stop faster but will reduce the chance of glazing your pads).
and FInally, If you truly want shorter stopping distances..... Get better tires.
Old Jul 30, 2004
Supercharged k20a3
well i have 4 wheel disc, i was one of the first guys to do it all the links you put up Mr. modify i had it before them, and i have 17's with yokohama perada spec 2's 215 40 17 so the tires grip
Old Jul 30, 2004
Zzyzx's Avatar
Autocross Junky
What pads are you using? and the 17s are also hindering your braking power... (Allong with acceleration).
Old Jul 30, 2004
Supercharged k20a3
i have honda pads, but what i really wanted to know is if i should just get the aem big rotor upgrade or save up for the wilwood kit
Old Jul 30, 2004
Zzyzx's Avatar
Autocross Junky
Nither; the stock pads are the problem, not the size of your rotors.
Old Jul 30, 2004
Supercharged k20a3
i know that i want more stoping power
Old Jul 30, 2004
Zzyzx's Avatar
Autocross Junky
All big brakes give you is Higher thermal capacity. Thats it. If you can control your heat problem with Better pads, then you are MUCH better off runing the stock sized rotors then a big brake kit. Simply because the larger rotor will hamper your acceleration.
Old Jul 30, 2004
Zzyzx's Avatar
Autocross Junky
Heres a good site that goes over a couple of common misconseptions regarding rotors..
From Big brake kits, to Cross driling
http://www.teamscr.com/rotors.htm
Old Jul 30, 2004
Mr.Modify's Avatar
damm why you gotta be putting my name in there? it's not like i care you did it first or anything? besides you should of posted or something on here to....maybe i would of posted yours first.......i was just posting a cuple of people that did it......
Old Jul 30, 2004
tfnaaf's Avatar
BLDNPSI Mod
ZZYZX you GD BIG WHEEL HATER !
Old Jul 31, 2004
Zzyzx's Avatar
Autocross Junky
Its not that I hate big wheels or big brakes, I just hate making a slow car slower.....
Old Jul 31, 2004
tfnaaf's Avatar
BLDNPSI Mod
^^^ Nod
henrytn
Aug 11, 2015 10:01 PM
swaff39
Aug 11, 2015 07:16 AM
honda.lioness
Aug 6, 2015 11:58 AM
DerbyDad03
Jul 27, 2015 11:34 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
