Can severely warped rotors cause wheel shake?
Old Jul 28, 2004
ccajun4real's Avatar
ccajun4real is an unknown quantity at this point
I have warped front rotors and have a mild wheel shake at above 62mph. The thing is I did not notice it with my steelies on however I do feel it with the 18s on. A mechanic told me that because the wheel is larger diameter I notice it more than with the 15 inch wheel? I looked at the sticky above but did not see this covered? Anyone had this happen? Thanks
Cajun
Old Jul 28, 2004
taz757's Avatar
It's possible that your rotors are warped. Also, there's a chance that your rims could be warped/bent or the could be out of balance. It'd be cheaper to get your wheels rebalanced first.
Old Jul 28, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
1. This is after wheel change.
2. Noticed at high speed, not when braking.
Centering rings or wheel balancing, not warped rotors.
And yeah, it's been beaten to death.
Old Jul 28, 2004
Aohan815's Avatar
Aohan815 is an unknown quantity at this point
your wheel would shake because of warped rotors when you brake not during regular movment, i mean if there is no contact with the actually rotor (ie when the pad touches the rotor) there is no friction on the uneven surfaces of the rotor or contact for that matter so i suggest you get an alignment and/or wheel balancing.
Old Jul 28, 2004
Balanced wheels, they are not bent, or so the shop told me. I am at a loss here....could alignment be an issue with new wheels? Thanks
Cajun
Old Jul 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Well, anytime you jack up your car and mess with rims or suspension you're probably changing your alignment the tiniest bit - just not enough to warrant an alignment job every time. Do you have hubcentric rings for your rims? If not I suggest the same as Sickboy - investing the $10 in them. Most people who feel vibrations above 100 kmh (60+ mph I think, my math is bad) need hubcentrics.
Old Jul 28, 2004
Sickboy's Avatar
Once again, do your wheels have centering rings?
Old Jul 28, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if your steering wheel is shaking at high speeds, that means your wheels aren't balanced, like aohan said
Old Jul 28, 2004
HondaLuver's Avatar
Its a celebration bitches!
disc's when braking, wheels not balenced when driving
Old Jul 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
^^^^ NOD
To the other post about alignments its IMPOSSIBLE for an alignment to directly cause a vibration. Vibrations are caused from rotating parts, never seen an Alignment rotate And jacking the wheels up off the ground WONT effect the alignment unless there are SEVERLY worn front end parts. And i mean SEVERE to the point that it was unsafe to drive 5 years ago. As for the rotors being severly warped to cause a vibration this too would have to be so SEVERE that when you used your brakes the car was falling apart from the pulsations this would be highly unlikely
Old Jul 29, 2004
Well based upon all of your quidance I am going back to the wheel shop and tell them to rebalance these damn things. Thanks for the help all
Old Jul 29, 2004
robbclark1's Avatar
Retired suspension supermod.
There are so many of you are spitting bad info. Hondaluver is right. Make sure you get laser balanced. The stupid firestone dudes or the like that place the weights by hand and don't know the exact amount SUCK!
Old Jul 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
im not familar with laser balancing, is this something new? I've seen balancers that use lasers to measure the wheel, and show where to put the weight, but never seen or heard of laser balancing.
Old Jul 29, 2004
robbclark1's Avatar
Yeah that thing. They are all computerized. They spin the wheel like those crappy ones but they have a special arm that the guy doing it uses to EXACTLY place the EXACT amount needed to balance the rim/tire. It should show him on the screen where the weight should go. The other ones, the guy just sticks the weight in the back, where it may or may not go.
Old Jul 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
in otherwords most comuterized spin balancers will do the job if the person running the balancer knows what hes doing. You dont want to send somone into a shop asking for a laser wheel balance and have the people in the shop laughing at him cause there is no such thing
Old Jul 29, 2004
robbclark1's Avatar
well I am not sure what it is called exactly.
Old Jul 29, 2004
Aohan815's Avatar
yea for some people no one knows that their talkin about
Old Jul 29, 2004
robbclark1's Avatar
just because I don't know what the machine is called doesn't mean I don't know what I am talking about.
Old Jul 30, 2004
Aohan815's Avatar
i wasnt talking about you
SimpleUser
Apr 24, 2021 02:54 AM
Dani1993
Jul 24, 2015 09:02 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
General 7th Gen
Jul 9, 2015 10:17 PM
