Rim offset and alignment ???
Old Jul 12, 2004
ALPHSTER's Avatar
THE FIRST LETTER!
ALPHSTER has disabled reputation
Question Rim offset and alignment ???
Do you have to compensate for a different rim offset than that of an oem rim when you get a wheel alignment? Or, is a wheel alignment the same regardless of different rim offsets?
Old Jul 12, 2004
tfnaaf's Avatar
BLDNPSI Mod
when you say a different offset how much different? If the center of the tire still contacts the road at the approx same place as before and the width is approx the same width as stock then you shouldnt need to offset the alignment at all. Its typically not an issue unless you are running RWD wheels on a FWD car where the wheel sticks out WAY too much beyond the fender. Or on 4-wheel drive trucks where your running a tire thats much taller then stock or much wider.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
