Help!!! EMERGENCY!!!
Old Jun 11, 2004
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
Alright I was chaning my brakes today and had my little STUPID! nephew over.
I was working on the drivers side first so I had taken off the two pads and had the caliper typed to the spring. Well my little nephew got in and pressed the brake all the way in exposing the piston to far!!!!! Now it won't go in, I spoke with Honda and they told me the caliper is screwed up! I went to a mechanic he said the same! Help! Where can I get a new caliper honda wants 146 for one!!!! help please!
Old Jun 11, 2004
Anyone?
Thanks
Well I went to my friends house which his dade is a head mechannic for this place and he fixed it. Said that I shouldn't have any problems until my next brake change. Then i would have to change the caliper. Sucks man!
Dooes anyone know a good website for nice calipers.Thanks
Old Jun 11, 2004
hondaautomotiveparts.com for OEM parts is good. Sorry about your brakes, but at least they're okay for now.
Old Jun 11, 2004
streetglower's Avatar
I am not sure about this, but I think rebuilding the caliper might help, but ask about that.
Old Jun 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
if the piston came out of the caliper it dont mean that its bad, as long as you push it back in without damage to the seal. As far as rebuilt calipers the aftermarket hasnt began making them for the 01+ civic that im aware of. But im sure that you can prolly get a rebuild kit ( Square oring and dustboot ) if need be.
Old Jun 12, 2004
lvc2's Avatar
lvc2 is an unknown quantity at this point
I'm not the sharpest tool in the shed but I've done quite a few brake jobs & I'm a little lost. Does anyone understand why the brakes would be OK now but wouldn't make it through another brake pad change??? I would think the caliper is either OK or it's not. Anyone?
Old Jun 12, 2004
tfnaaf's Avatar
BLDNPSI Mod
Do you mean the rotors are ok now but wouldnt make it through another brake job? If so that means that they are getting down to the min. thickness or machine to thickness and cant be reused.
Old Jun 12, 2004
Ok guys here is the update. Thanks for all the info. The piston was resored and it works fine. There is one problem though
Before I changed my pads and brakes there was a loud sound coming from the front left. When I inpected it, the front left rotor was scracthed deep! alround the edge on the rotor. Something was on the rotor that sunk in and embeded itself.
Now that I put on the brembo's, axxis pads and flusehd the system it still does it!! What the hell! My new rotor is messed up. There is an even louder noise when I drive and turn and stuff. Seems like something is rubbing against the rotor. It's not the pads because the pad will rub no matter what without doing that damage. I dont' kow what it could be. ANYONE THAT MIGHT KNOW PLEASE HELP ME
Old Jun 12, 2004
Alright nevermind the problem was solved. You see Tireplus! Messed up my car gain! They didn't tighten the nut that goes onto the axle.
