215/40/17 or 205/40/17
Depends on the offset of the rim and how low you wanna go. If you are at 40, you wont have a problem with either. Im dropped 3" in the back on 215/45/17 and I havent rubbed, but I still have - camber.
I'd go with 215-45-17
It woulnd't rub if you don't drop
more than 2" i believe.
I'm about to drop it 1.75 F 1.5 R
with 205-40-17 but i wish i had 215-45-17 or 205-45-17
Retired Super Mod and STILL Pimpin' Yo Mama
Re: 215/40/17 or 205/40/17
Originally posted by ati9700pro
which one? and will either of these rub
Im dropped almost 2.75" all around on 205/40/17...
I have 205/40/17 right now. You will not rub at all with this setup. I want to go 215/40 or 215/45 when these tires wear out. I have a 1" drop with eibach pro. Which, after settling, is something like 1.4".
Id go with 205/45/17 or 215/45/17 just beacuse its closer to stocka nd wont mess your speedometer much plus 45's are much better because of the extra cushion 40's would be a rougher ride and potholes would hurt.
Originally posted by 7thgencivic9
so basically the 215/40/17 would be a wider tire than the 205/40/17 right? what difference would it make on the width of the tire as far as handling?
