perfect time to pump your tires?
Old May 2, 2004
zen_master's Avatar
hi guys, i've searched a lot of our threads regarding my question....still..
when is actually the perfect time to pump our tires?
OK, i know that i should leave my car for about few hours in order to "cold' my tires....
I've read lots of articles about this...including the one in tirerack.com
now....as we know, the tire's pressure depends on the ambient temperature...
so, what do you guys think about the perfect temperature (F) to pump your tires?
in the sense that I've let my car and the tires cool down for several hours...
right now, i just realized that i did something stupid....i re-pressurize my tires at 30psi on "hot/warm" condition....which resulting in low-pressure just now when i checked it...it's actually on 24psi on this "cold" condition...
the temperature right now in my area is 46F.....and I haven't drive my car for the whole day...
just now, i re-pressurize my tires at 30psi on the same condition...
what do you guys think? this might be one reason why i got low MPG....
Old May 3, 2004
zen_master's Avatar
opinion, guys?
actually...the car's running nicely now..
oh yeah....i actually filled up my gas tank again after inflating the tires to the correct psi..
let'see..
i filled up 12 gallon the night before i pumped my tires.....i drove 39 miles before re-fueling my car...
the thing is, i filled 1.3 gallon at that time..........
say, 1.3 gallon for 39 miles @ 24 psi tires..............BAD?
Old May 3, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
I think maybe you are thinking way to deeply into the concept of putting air into your tires. Just put 35 psi in there or whatever the reccomended amount is and check it again in a couple days. if you are having to consistantly re-air them, you could be having a slow leak. Your lesser inflated tires will give you more of a smooth ride, but will wear the treads faster. Over inflating your tires will reduce overall wear, but may induce uneven wear, and will make for a rough ride.
Old May 3, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
The perfect time to check your tires is usually in the morning because the tires have cooled down AND because it is usually the coldest time of day that you will be driving during. So, set your psi to 30 or whatever psi you would like, during this cold time so you know you are always driving around on a minimum of 30 psi.
Old May 3, 2004
zen_master's Avatar
Thanks for your input guys...i really appreciated it...
well...to be honest, i put it to deeply into my mine because it might be one of the factor why i got such low MPG..
right now, im bitching about everything which might lower my MPG....including the sparkplugs...hm....which i think im gonna change in the next few days...
Old May 3, 2004
Zzyzx's Avatar
Autocross Junky
you want to save gas.... Use less Right foot. accelerate as slow as you can, and cruze in the highest gear you can. Low RPM = Less gas used.
Old May 3, 2004
Roy's Avatar
Roy
Roy is an unknown quantity at this point
get the right alignment settings and psi... drive 70mph on the freeways... and you'll be like me. 36-37 mpg consistently.
Old May 3, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
ive found that 39 miles is not enough of an interval to "check" your mileage. let it go till you are almost out(on E amybe). this way the tank will have had a better aveage of what your normal driving habits are. example, at around a half tank, i can have anywhere from 80 miles to 140. whereas if i go to near empty i usually have 240- 280 miles. point being, if i would look at my mileage with 80 miles i would think "Man, that sucks". but, on that same tank, i may get a high 280, witch will have greatly improved my MPG. also, when you want to fill up, dont keep clicking it to "top it off". this will make for inconsistant readings. i always fill it to the first click. that makes for more of a consisntant reading.
Old May 3, 2004
btw, i have an Si, which explains my 28-30 mpg average. with my EX coupe, i averaged between 34-37 mpg
Old May 3, 2004
Zzyzx's Avatar
Autocross Junky
Half a tank = 80-140!!!!??? damn, our gas gagues are bad. I'll have 100 on 1/4 down. When I drive down to San Diego 320 Miles, i can get there and still have a quarter tank left.... And I have an EX! (as long as I cruze at about 70-75)
Old May 3, 2004
yeah, my record with the EX is 457 miles on about 12 gallons
Old May 3, 2004
robbclark1's Avatar
Retired suspension supermod.
i am usually around 400 miles per 11 gallons lately.
mattdoc
Mar 14, 2017 12:10 PM
bo_red
Apr 23, 2015 10:09 PM
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
technosilver
Nov 14, 2001 10:58 AM
