brake caliper
Old Apr 3, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
brake caliper
i was wondering how do u know when it's time to replace your break calipers??? because i rarely heard of people changing them, but break shops always wanna replace them
Old Apr 3, 2004
Zzyzx's Avatar
Autocross Junky
^^ they want to replace them for the $$$$$^^^
Theroetically brake calipers should last the life time of the car, but theory rairly = reality. really, you should only replace them if they are damaged or if the seals are going bad. How long that is...... Dont know 100,000 miles, 200,000??? depends on how hard you are on the braking system.
Old Apr 3, 2004
ok thanks
Old Apr 3, 2004
Titleist71's Avatar
calipers should last a longtime...I'm not sure but if the car sits for a really longtime they may seize up from lack of use...then I'd get new ones.
Old Apr 3, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Calipers have seals that could wear out. But they can easily be rebuilt, Honda has rebuild kits, so the cost is not the same as needing a new caliper.
Now rotors and pads wear out all the time. The rotors can be turned, but heat will warp them and cause the need for replacement.
Old Apr 3, 2004
tfnaaf's Avatar
BLDNPSI Mod
Its very common anymore to replace the brake calipers and or wheel cyl's when doing a brake job. You know how a Body shop says they cant garuntee thier work unless they take it down to bare metal and prep and build out from there? Well its sorta the same with brake cailpers. When you do a brake job with out replacing the caliper you have to press the piston back into its bore to make room for the new pads. This can sometimes cause the piston and seal to run back in an area that it wasnt used to and cause a problem. Is it common for calipers to fail after doing front brakes without replacing them ? Not terribly but it does happen. What i would suggest is if they are a repuable shop that you trust. Follow thier recomendation. Did they mention if your brake pads were wearing even from side to side, and maybe this is why they are recomending replacment of the calipers?
Old Apr 3, 2004
tfnaaf's Avatar
BLDNPSI Mod
Oh, i forgot to also say that there is no way of setting a milage or time frame on when and if you should replace calipers/wheel cyl's. ive seen failures on brand new cars with less then 5,000 miles. But then again ive seen cars with 100,000's miles and never replaced ever. My personal recomendation is replace/rebuild every time after all they are your brakes. They fail and life is at risk!
Old Apr 4, 2004
streetglower's Avatar
just get them rebuilt. Its like $25 a caliper.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
