Wheels and tires
Old Mar 7, 2004
straightfaced's Avatar
straightfaced is an unknown quantity at this point
Lightbulb Wheels and tires
I am buying 17" rims but dont know what size tire i need. my car is lowered with the
eibach sportsline kit and i want to get the perfect series.
what size of tire would I need 215/45/17?
Old Mar 7, 2004
civic-king's Avatar
civic-king is an unknown quantity at this point
i would think that's fine.
or:215/40/17 205/40/17 205/45/17
Old Mar 7, 2004
pheaton's Avatar
A descendant of 2k1civic.com
I wish I had money for wheels/tires. .
I would say 215/40/17, unless your local roads suck. If they are really messed up roads, really bumpy, I would go 215/45/17 for a little more rubber between you and those bumps.
Old Mar 7, 2004
yeh i live in winnipeg manitoba and after the winter the roads are the *****, tons of potholes.
I just dont want to get the wrong size and then my car doesnt look like it has been dropped.
Old Mar 7, 2004
XenonCiv01's Avatar
XenonCiv01 is an unknown quantity at this point
go with 45/17.... its always good to have some extra meat on the tire. i have 205/40/17 and the rim sticks out a little so it i touch the curb my rim gets scracthed. with 45/17 tires you dont have to worry about that i think
Old Mar 7, 2004
so 215/45/17 would be a wise decision
Old Mar 7, 2004
civicvtec1ps's Avatar
Search and Learn
Moved to Wheels,Tires & Brakes
I highly recommand 215/45/17.
Old Mar 7, 2004
flotsamm's Avatar
I have the same springs and 205/40/17 tires on 40mm offset wheels. I've never scraped or rubbed yet. 205's are pretty safe with most wheels. I wanted 215/45/17 tires for comfort and wheel protection, but was afraid that they'd rub. A 215/40 isnt much taller(only 4mm) but is more expensive and 10mm wider(5mm each side). If you have a wheel with a good offset(42mm or more I'd guess) then you might be able to get away with no rubbing. You could probably get away with 205/45/17's, though the price goes up alot over 205's.
Old Mar 8, 2004
pheaton's Avatar
^^ True. . either width though is wayyy wider than stock. . which is good. . "Wider is better". .
Tedverseti
Apr 23, 2020 01:45 PM
jzhartman
Jul 9, 2015 04:56 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
