tire pressure for 215/35/R19???
Old Mar 6, 2004
fatboy's Avatar
fatboy is an unknown quantity at this point
Question tire pressure for 215/35/R19???
i got some pirelli pzero nero 19s. How much PSI should I be running? I'm currently running 40psi. People have told me 30, 35, 40, and even 43. So what's ideal?
Old Mar 6, 2004
ImPulse's Avatar
should be asked in the tire section
Old Mar 6, 2004
kyle4583's Avatar
207 Mod is 10-8
kyle4583 is just really nicekyle4583 is just really nicekyle4583 is just really nicekyle4583 is just really nice
isnt it labeled on the sidewall of the tire?
Old Mar 6, 2004
fatboy's Avatar
it just says "max 50psi"
Old Mar 6, 2004
ImPulse's Avatar
so do like 45
Old Mar 6, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
ImPulse so do like 45
Agreed...
Old Mar 6, 2004
civicvtec1ps's Avatar
Search and Learn
Moved to Wheels,Tires & Brakes
Old Mar 6, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
put in what is on the placard sticker in your door jamb. should be around 30-35 psi. the tire sidewall lists its max safe operating pressure. the pressure recommended on the placard should work for most, if not all, tires. if id didnt, it would say, xxpsi for x model tire of x size
Old Mar 7, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
You should only put what it recommend by the manufacturer on stock tire sizes, and not on low pro tires. Honda doesn't take into consideration that you will be buying different tire sizes, nor does any other car manufacturer.
If the tire says like 50 psi, I would put in 40. 45 psi is good, but I usually like to go a little under to compensate for more traction, and weather conditions. In hot weather, tire pressure will go up, and in colder conditions, tire pressure will go down.
Old Mar 7, 2004
HondaLuver's Avatar
Its a celebration bitches!
^^^ so if its really cold out side, put some more presssure, as soon as it starts to warm up put less... usually the harder the ride, the more pressure, and less traction. i would suggest 40 psi just for a all around pressure
Old Mar 7, 2004
tfnaaf's Avatar
BLDNPSI Mod
From my experince i wouldnt recomend above 40psi even if max = 50psi. When you get to the higher end of the psi it tends to cause the center section of the tread to become somewhat of a knife edge and can cause the car to feel very unstable at higher speeds. You may want to start around 40 and adjust it down until it seems to drive the best. I wouldnt recomend much lower then 32 psi thou.
Old Mar 8, 2004
fatboy's Avatar
ok, thanks everyone. i'm riding on 40 psi as of now
Old Mar 9, 2004
samscivic's Avatar
samscivic is an unknown quantity at this point
i use 35 in my pzeronero w/ c5s but 18's - no problems + very comfy + i live the way pzeroneros handle and feel . what kinda drop do u have?
Old Mar 9, 2004
fatboy's Avatar
Gcs and KONIs w/ no wheel gap front n back
Old Mar 9, 2004
samscivic's Avatar
what would give me like .5 - 1'' gap?
Old Mar 10, 2004
fatboy's Avatar
a couple of fat chicks
Old Mar 10, 2004
phuviano's Avatar
LOL... your talking like you know from experience. LOL.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
cukaracha
Jul 23, 2015 08:50 AM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
