Brake Squeek
Old Mar 7, 2004
pheaton's Avatar
A descendant of 2k1civic.com
Brake Squeek
I don't know if this needs to be in here, or in the Vehicle Issues section, but I'm just gonna slap it in here..
When I let off the brake pedal there is a squeek. Sounds like it's coming from the front. What does everyone think the cause is? Should I bleed the system? Lubricate the calipers?
Old Mar 7, 2004
HondaLuver's Avatar
Its a celebration bitches!
check your brakes, it might mean that you need new pads because of the metal indicator rubbing against ur rotar. usually for some reason the pad on the inside is worn out more than the ones on the outside
Old Mar 8, 2004
pheaton's Avatar
Hrm. . A worn pad would cause a squeek when I release the brake pedal?
Old Mar 8, 2004
streetglower's Avatar
I have the same problem, when I release the pedal when I stop, I hear a squeek. It is coming from the rear though. I had it on my last car, so I dont worry too much about it.
Old Mar 8, 2004
I personally think it is just parts releasing from something and making noise, I dont think it is a big deal though.
Old Mar 8, 2004
ImPulse's Avatar
yea i have that too... whenever i take my foot of the break u hear a lil squeek/air type sound?
Old Mar 8, 2004
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
i get that too!! but then i just changed my breakpads and installed some Hawk ceramic pads. anyone know what this could be?
Old Mar 8, 2004
ImPulse's Avatar
is it still there with the new pads? or is it gone?
does it feel better breaking with hawk ceramic pads?
Old Mar 9, 2004
iLLuMiNaTi's Avatar
the braking feels a lot smoother and more solid, but the squeeking is still there. It really doesn't feel like it should be squeeking, judging by how they seem to perform.
Old Mar 9, 2004
I still dont think it is anything to worry about.
Old Mar 9, 2004
Zzyzx's Avatar
Autocross Junky
Its a little known fact that All brakes squeak. Just most of the time its beyond the range of human hearing. As far as squeaking when your not pressing onthe brakes, well the pad is still rubbing on the rotor, just with out any force behind it. So there is a possiblilty that they could be vibrating on the rotor (Squeaking).
I suggest pulling the brakes appart (Remove the pads) and re applying some Anti Squeal compound to the backing plates on the pad and re installing them.
also, some brakes just squeal more, metlic brakes for example tend to squeal for no good reason, and some High performance brakes squeak too.
Old Mar 10, 2004
sean2sean's Avatar
sean2sean is an unknown quantity at this point
http://www.sts.sae.org/membersonly/t...tidbits-05.pdf
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
