Speedometer accuracy with rims/tires?
Old Feb 6, 2004
Hypnotik's Avatar
Hypnotik is an unknown quantity at this point
Ok, well I did some calculations, and was wondering, how much of a difference will a 5% increase in the total diameter of the wheel and tire make as far as speedometer/odometer accuracy? Also, is it possible to get the speedometer adjusted by the dealer to compensate for the difference? (since I know Honda sells larger wheels)
Here's the numbers for anyone interested:
Stock 15x6 Honda Wheels
Stock 185/65/15 Firestone Tires
185mm X .65 = 120.25mm sidewall
120.25mm X .0394(in/mm) = 4.738" sidewall
4.738" + 15" = 19.738" total diameter
Custom 17x7 Wheels
Custom 215/45/17 Tires
215mm X .45 = 96.75mm sidewall
96.75mm X .0394(in/mm) = 3.812" sidewall
3.812" + 17" = 20.812" total diameter
Even running 205/40/17 tires, the total diameter still increases by 1/2 inch. Oh, and I just realized that the stock numbers would be for the EX, does anyone have tire sizes for the 14" LX wheels?
Old Feb 6, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You need to multiply the sidewalls by 2, there's 2 sides to the tire when you measure diameter. The diameters should be more like 23.8-24, and there's only about a tenth of an inch or so difference between a 215/45/17 and a stock 185/65.
Old Feb 7, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
Hes correct. If u look up the stock tire on firestons website it tells u the overall diameter which is pretty close to 23.6 or .8 if i remember correctly. 45's will be much closer to the stock diameter compared to 40's. And i dont thin honda will change the speedometer cus that would requrie tampering with it. But then again its prob just bets to call honda and ask.
Old Feb 7, 2004
flotsamm's Avatar
I run 205/40/17's and when cruising with everybody down the highway I dont even notice a speed difference. I can trail the person in front of me who's doing 70mph and look at my speedo and it'll say 70mph also. I think of it this way, when your doing 100mph, you really only doing 95mph. If your doing 50mph, your really only doing 47.5mph. It was a big concern of mine at first but now I realize it doesnt matter.
I think to recalibrate the speed you'd have to get the ECU reprogrammed or use some other device that can adjust the ECU programming.
Crazygrlinak
Oct 8, 2015 05:06 PM
260000milesgoal
Sep 25, 2015 07:41 PM
jerry38
Sep 20, 2015 08:38 AM
MamaBear2015
Sep 15, 2015 09:35 PM
Bricoleur
Sep 9, 2015 06:48 PM
