please fully explain to me how offset works.
Old Jan 25, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
fro my understanding if the wheel is 19x8 then u go in the middle which is 4" and then u would go out whatever the # is.... so like a +45 means u go out from center 45 milimters? and if its a - offset u go in???? am i riught im j/w causeim getting some 20x8's i think and their +47... if anyone knows the proper way this is measred please post below im guessing it'l be lke boiler maker or zzyxzy
riley
Old Jan 25, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Straight out of the ".... Want to know about rims thread"
It depends. If there is not enough offset, you'll have trouble with the brakes fitting in. There are also some rims with very wide lips ("Deep Dish") that are intended for RWD cars that may not work. The offset is the distance (in mm) from the centerline of the rim to the mounting face on the rim. Positive offsets will bring the wheel further into the fenderwell, Negative will push them out. Anything in the 37-44 range should work no problem, but it also depends on how wide the new rim is. Remember that the offset of the new rim is relative to that rim, NOT the stock one. Assuming positive offsets (you shouldn't use negatives, the car will be bowlegged): If the new wheel has less offset (lower number), add the offset difference to 1/2 the difference in width between the 2 rims. If the new wheel has more offset, subtract the offset difference. Less than stock will push the rim further out, more than stock will pull it in.
Offset Calculator - It's a little cheesy, but it works... it's an excel spread sheet so just open it when it asks.
Go into that thread and click the link to the offset calc. You can see what will change.
You're not going to get 47s on the car. No way... you'll hit the suspension.
Old Jan 25, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
ok thanx im sorry for not looking thanx boiler maker i knew i could count on ya.
riley
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bruce2
Sep 27, 2015 08:45 PM
jsmithe2010
Sep 25, 2015 07:42 PM
