Offset? Rub?
Old Jan 12, 2004
Macko's Avatar
Macko is an unknown quantity at this point
Offset? Rub?
for 17 inch rims... what offset is recommended? assuming that i'm running tires wit the same overall diameter as my stock
Old Jan 13, 2004
666's Avatar
666
666 is an unknown quantity at this point
If your wheel width is between 7" and 7-1/2" which it probably is, stick with something in between +40 to +45. Most wheels will be +42 and that seems to work perfectly for most. If you are dropped or are planning to drop your ride alot you may want to stay with a higher offset (something closer to +45) so the wheel will sit in the fender more and have a less chance of rubbing on your fender.
Remember your lug pattern is 4X100, and your lug size is 12X1.5" too.
Old Jan 13, 2004
Macko's Avatar
thanks yo..
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
Strycker
Aug 18, 2015 02:25 PM
