18's..
Old Jan 10, 2004
Cocky's Avatar
Cocky guys kick ass!
18's..
18" rims on a 2" drop (front) and 2 1/4" drop (back) should i have any problems?
Old Jan 10, 2004
666's Avatar
666
666 is an unknown quantity at this point
Depending on the offset of your wheels you should be okay, you may have to run a little more negative camber than stock in the back to keep the tire from rubbing but you should be fine.
Old Jan 11, 2004
sspem2's Avatar
em2
you should be fine. i got 18's and dropped 3 inches and i dont rub. i got perfect camber to. just had an alignment.
Old Jan 11, 2004
alpinecivic02's Avatar
alpinecivic02 is an unknown quantity at this point
i havent had any problems with mine...i am tucked in the front and a finger gap in the back.....i just need to get that alignment and ill be good to go
Old Jan 11, 2004
Cocky's Avatar
i found a tire/wheel set for $800 on this website, 225/40-18.. any problems there?
Old Jan 12, 2004
Green Civic's Avatar
On sharp turns, you may rub. Not sure though. You would be fine running 215/40/18. Check the tire calculator:
http://www.7thgencivic.com/modules.p...tor&file=index
kinez
Nov 4, 2006 11:24 AM
Mralbino
Florida
Oct 5, 2006 07:01 AM
chibOi
Aug 12, 2004 04:01 PM
Dizzymofo
May 1, 2002 11:07 PM
