brake troubleshooting
Old Jan 9, 2004
Dimplebutt's Avatar
Dimplebutt is an unknown quantity at this point
Hey guys. i have a 2k2 ex coupe and i was wondering if i could get some help. I have about 45k miles on my car changed the pads around 22k and i'm getting this weird grinding sound from my brakes. This only happens after the brakes heat up. IE: the end of a drive.
i push the brakes and i hear this grinding sound like A low pitched grind. I know it's not the pad i had my local mechanic look at my pads and there's about 35% left. i actually saw it too. Either way i plan on changing the brake to some Hawks in about 2 months, i was just wondering if i needed to change the rotors with it.
BTW: i'm also going to change the tires from stock crap to some falken ziex-512.
any help is appreciated. thanks guys
Old Jan 9, 2004
Dimplebutt's Avatar
NM.. found a similar topic in issues it looks like i need to change rotors..any recommendations?
Old Jan 9, 2004
Roy's Avatar
Roy
Roy is an unknown quantity at this point
well, if you get blanks, i'd just get oem replacements. if you're looking to spend the money, i guess brembo. cross drilled/slotted if you want, but not necessary.
Old Jan 9, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
check the wind felector that is behind the rotor. It could be rubbing on the rotor...
just bend it back some.
Old Jan 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
If everything looks physicaly ok it could be just nature of the beast. Some brands of braking material make more noise then others.
Old Jan 9, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
If you want blanks, do not get OEM ... Brembo blanks are better and cheaper.
Old Jan 9, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
If your rotors are not too terribly warped, you can have them easily turned. You will have to replace the pads as well, but that should restore your braking to normal.
Our cars have small rotors and warp fairly easily, so unless you change them aftermarket, keep it easy on the power stops, or be prepared to turn them and replace the pads a lot.
Kind of the curse of HONDA.
Old Jan 9, 2004
Dimplebutt's Avatar
the curse of honda yes.. haha.. well umm kj thanks i'll check that out.. whatever it is.. i'm sure i'll see it.. but yeah.. i'd rather get aftermarket rotors over oem.. Everything OEm on our car is quite the P.O.S so i might as well change it. I dont' think that they're warped cuz the wheel doesn't vibrate.. it's just a grinding sound that i hear and feel in the brake pedal.. it still works and stops but that sound bugs.. Thanks for the replies
anyone know some good places for rotors?
Old Jan 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
the noise could also be caused by dust build up on and around the pads. Sometimes cleaning them with some brake cleaner will correct it too
Old Jan 10, 2004
Dimplebutt's Avatar
thanks tfnaaf i'll give that a try too
Old Jan 16, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i just installed new rotors and pads back in early november. just recently, when I brake slowly at low speeds, i get a grinding noise (actually sounds more like a liquidy-boiling-grinding noise). The noise only lasts for maybe one second, which is right before I bring the car to a complete halt. I notice it happens more (or maybe only happens--) when the brakes have had time to cool.
the noise is either coming from the brake pads, or even possibly from the brake fluid reservoir itself. sitting in the drivers seat when you brake, it's hard to tell exactly where the noise is originating.
instinct tells me to bleed the brakes, but if you have any other suggestions, please. i've only used approved DOT3 fluid, except maybe 5 months ago i went with valvoline's DOT4 ABS fluid.
don't know if this is related, but i am also developing a squeak when braking now, too. all 4 pads are definitely thick. I am using slotted & dimpled ProStop rotors with EBC greenstuff.
Old Jan 16, 2004
Dimplebutt's Avatar
wow.. now that's interesting. mex. hmm...i'm very interested in this also..
SidCivic
44
Oct 12, 2017 03:39 PM
cncnut
Aug 23, 2015 01:25 PM
Low_Lupe
Aug 17, 2015 10:57 AM
honda.lioness
Aug 6, 2015 11:58 AM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
