Tire Sizes????????
Old Dec 30, 2003
PeN8503's Avatar
PeN8503 is an unknown quantity at this point
Tire Sizes????????
ok im gettin some new rims right, and i wanted to know what all the numbers meant on the tires. i know the last one is obviously the rims size. tell me the differnce between all these tires.
(225/40/18)
(215/35/18)
(235/40/18)
i know basically some are thicker and wider than the other but which one would be the best bet. i dont want the thinnest one. i want 18s with a little bit thick rubber.
thanks in advance
Old Dec 30, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
First number is the width in mm
2nd is the aspect ratio - its a percentage of the width that makes up the sidewall. (Width x aspect ratio %)/2 = sidewall height
3rd is the rim size
215/35 is the thinnest
225/40
then 235/40
I doubt that 225/40 will fit on a significantly lowered car.
Old Dec 30, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
hmmmm try here!!!
http://www.7thgencivic.com/modules.p...tor&file=index
Old Dec 30, 2003
666's Avatar
666
666 is an unknown quantity at this point
Since you want a tire with some rubber, I would reccomend a 215/40-18. Like Boilermaker1 said the 225 will be a little too wide and may rub, so you can ignore those sizes.
Here is VnlilMAN's Civic, he has 215/40-18's to give you an idea.
Old Dec 30, 2003
Mr.Modify's Avatar
yea 215/40/18s are perfect!
Old Jan 2, 2004
PeN8503's Avatar
ok then thanks alot guys.
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
