LOUD scratchy sound by wheel...
ok..i backed out of my garage today like a normal day but i noticed this ungodly loud scratchy sound coming from the right side front tire...its horrible...i thought it was jsut from backin up and it would go away...but when i start to drive down the road it still scratches really bad...but when im drivin then i brake..it will stop but once i let off the brake it starts back up..but if im goin over 60 and i brake it just continues to make the scratchy noise...anyone know whats goin on? its so loud peopel can hear it from like 50 yards away and look at me...
i jsut dont understand though....how can it be my brakes when it makes this LOUD squeaky sound when im just drivin on the fourlane or anywhere else...the sound actually stops when i use my brakes...
Originally posted by civic12
if i take it to the honda dealership will this be under warranty? i got my car in febuary...will new brakes be put under warranty?
I experienced a VERY loud screeching from the front rotor on a '94 accord several years ago...
It was caused by gravel from the road getting stuck behind the dust shield on the caliper ***'y
It might be worth a look...I just flexed it by hand to allow the gravel to drop out. This happened 2 or 3 times while I owned it. Hope this helps!!
I experienced a VERY loud screeching from the front rotor on a '94 accord several years ago...It was caused by gravel from the road getting stuck behind the dust shield on the caliper ***'y
Good idea but it wouldnt be the dust shield cause you have 2 constants the rotor and shield. Neither change physicaly to cause a change that hes describing. Dust shield would be a constant noise unless the wheel bearing was so worn out that the car wouldnt be driveable.
andyandyy
Aug 4, 2015 06:37 PM
Hqly2001
Jul 25, 2015 05:32 PM
1khilari
Jul 9, 2015 08:12 PM
