tuner lug nuts?
Old Nov 12, 2003
pitciv's Avatar
pitciv is an unknown quantity at this point
tuner lug nuts?
on an ebay item i'm considering buying (rims) it says the tuner lug nuts are not included but are required...why can't i use stock lug nuts?
Old Nov 12, 2003
jblayz1's Avatar
jblayz1 is an unknown quantity at this point
...try it
Old Nov 12, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
1. Tuner lugnuts have thin shanks so you can get a key over them or in them to get them on and off. The wheels are designed so the lugnuts fit tightly into the countersinks drilled for them, rather than providing a lot of room around them to get a regular nut and socket on to.
2. Stock lugnuts have a ball nose. Almost all aftermarket wheels have conical tapers... which means you need to use a cone-ended lugnut. Using a ball lugnut in a conical hole WILL ruin the wheel.
I think that should suffice as reason enough.
Old Nov 12, 2003
pitciv's Avatar
hmm...definitely DONT want to risk screwing up my (or will be my)expensive rims...do i have to get wheel specific tuner lug nuts or any type?
what is the key for? protection?...ppl steal rims....
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
AffliictiioN
Sep 16, 2015 02:21 PM
siliconvalley
Sep 15, 2015 09:48 PM
