PSi cold measure
Old Sep 21, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
Question PSi cold measure
hi, i got a set of 98-2001 corolla S rims today for my mom's car... i was wonderin what psi should i run them while cold? because i read the sidewall and it said max. pressure 44psi... i've only dealt with 35psi max pressure tires before... i always had those set to 32psi... should i set these tires to 40-41psi??? i remember my auto tech teacher always tires 1-3psi lower than the max pressure for optimum performance... doesnt 40psi sound a little too much??? thanks for any inputs!!
Old Sep 21, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Well if you've got corolla S wheels, then I assume they're for a Corolla... in which case, look in the door frame.
If they're 15's then go for 30-32, 16's go for 32-34. The fact that the max is higher is just a testiment to the structural durability of the tire. It can take more before its dangerous, you shouldn't set it that high. My Yokos are good to 51. I drive around on them at 35 on the street, 42/33 on the track.
Old Sep 21, 2003
whitensimple's Avatar
whitensimple is an unknown quantity at this point
The max pressure is basically for legal reasonings. On some tires it'll say Max Pressure XX (only in US and Canada) I'd recommend probably 32. In the winter though it's gonna go pretty low so maybe 35.
Old Sep 21, 2003
the tires are 175/65/14R... i have them filled to 32psi but they seem kind of flat to me... like the sidewall bulges out...
Old Sep 22, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
yeh, i filled them 32psi, and it said 44max on my tires.....got questions thou....if i lower my car, is that goin affect the tire pressure, cuz before i lower my car was 32psi, after couple weeks then it read 26psi, is that means stiffer suspension lose more air?
Old Sep 23, 2003
Mbow's Avatar
I don't see how people combine the thought of "MAX" pressure and what the tire should be run at.
32psi is generally the most recommended pressure for street use.
Old Sep 23, 2003
well in high school, my auto tech teacher, who was ASE certified, said that generally u should fill up the tires 1-3psi less than the max... but i thought to myself filling to 40psi seems kind of too much... but when i did fill them to 32psi they seemed kind of low on air, by that i mean the sidewall bugles out.... on my civic i filled the tires to 32psi and the sidewall bulges out only a little bit...
Old Sep 23, 2003
Mbow's Avatar
The sidewall is going to stick out. The car is heavy you know. You don't judge tire pressure by the sidewell unless it's very flat or something...LOL
1-3psi less than max...WTF!! Goes to show you how much an ASE certification means.
Old Sep 24, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
i run 45 psi on the street, no problem. My tires take upto 51 psi. It gives the tire a stiffer sidewall (more support for cornering). My tire wear is pretty even across the tread. You should check what the tire manufacturer reccomends, as you want to have a tire that will be flat on the road at operating temperature.
(You can then just see how your tire wear looks across the tread & adjust slightly if needed. You should have proper alignment to try this & a lot of miles at the same pressure, if you want to play around. Or better still, check the temperature across the tread after driving & adjust.)
Old Sep 25, 2003
solar's Avatar
solar is an unknown quantity at this point
Well you could go by your teachers advice, but the car is going to feel like you have rocks for tires, you'll feel every bump in the road and probably find some new rattles.
Old Sep 25, 2003
i stuck with 35psi since the cold season is starting... seems good so far...
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
Nalmonte
Sep 28, 2015 01:10 PM
