'02 LX front brake upgrade?
Old Aug 25, 2003
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
Ok, my brakes are needing to be replaced. This car is only a daily driver with little romps on country roads. What should I be upgrading with? Pads-Brand? Rotors-brand? Calipers? How extensive should I go? I should be replacing the lines with stainless steel, right?
Old Aug 25, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
how many miles are on your car? since your car just just a daily driver, you only need to replace your pads/rotors. OEM parts should be fine
Old Aug 25, 2003
it has 25k on it, I was thinking maybe pads or something upgraded just to increase the performance a little.
Old Aug 25, 2003
PunkingCivic's Avatar
I need TP for my bunghole
Old Aug 25, 2003
neuspeed cross drilled brake roter for a littler better cooling and brake dust disipation.
They are like $184 for a set. They have performance Axxis brake pads as well for $28.35 per side.
On the site they don't have the drilled roter displayed yet, but they have them in stock.
Old Aug 25, 2003
C0rnfl4k3's Avatar
C0rnfl4k3 is an unknown quantity at this point
I have the AEM slotted big rotor kit it was $400 for the set and includes bracket to use the stock caliper. I have no complaints about them.
Old Aug 26, 2003
FYI... that is a great kit, but only if you have 16 inch or bigger rims.
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
edspyhill09
Jun 12, 2016 02:45 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
rhvic
May 22, 2015 03:06 PM
bsmiley
Apr 27, 2015 01:27 PM
