Buldge in Tire?
Old Aug 15, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Question Buldge in Tire?
Hey everyone, I have fairly new Konig Rated R 17" Rims with Khumo 215/45/17s. Today when I got home, I noticed that in my front passenger side tire, there was a buldge right on the M in Khumo. I got these tires and rims in march so I still have a warranty and discount tire will replace the tire. Is it just the tire and that there is basically a chance for this to happen to any low profile tire? I haven't curbed my rims, but could going over a big bump cause a buldge to appear in the side wall of a tire? I just would like to know so if there was a chance that I caused it, I would know what not to do. Thanks
Old Aug 15, 2003
civicvtec1ps's Avatar
Search and Learn
tire is defective. just get it replace. shouldnt matter because of low profile tire
Old Aug 15, 2003
TonySTiX's Avatar
TonySTiX is an unknown quantity at this point
If you go over a big pot hole it dont matter what kind of low profile tires you have, your gonna get "bubbles" or "bulges" because you now have a hole in the inside of ur tire causing air to escape and create the bubble.Its good to have tires with some kind of warranty. If i get bubbles because of pot holes i get a new tire for $30 (old tire traded) which is a big reason i got the tires i have (Aurora,which is yokohama)
Old Aug 16, 2003
ZSKCivic01's Avatar
Extreme Member
My Khumos are still under warranty, all I had to pay to get the tire replaced was $25.
Old Aug 17, 2003
fastlx's Avatar
fastlx is an unknown quantity at this point
It is in most cases called an impact break. It is caused by compressing the tire between the wheel and another object (usually a pothole). It causes a tear in the carcus (sp) of the tire which allows air to get inbetween the plies of the tire. It happens more on lower profile tires due to the height of the sidewall. Hope this helps.
Chris
Old Aug 17, 2003
TonySTiX's Avatar
Thumbs up Tires
Chris
Yep. Exactly.
Old Jan 8, 2004
TuffVietta's Avatar
TuffVietta should not be trusted
i was wondering if this is repairable or do u have to get a new tire? also, how dangerous is it to drive like this? thanks for any responses.
Old Jan 8, 2004
Zzyzx's Avatar
Autocross Junky
1, its not repairable, and 2. yes its dangerous to drive with it, because the side wall could blow out, and you dont want that happining on the freeway at 65+ mph.......
Old Jan 8, 2004
tfnaaf's Avatar
BLDNPSI Mod
nod
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
