Front Brakes
Old Jul 17, 2003
triumph439's Avatar
triumph439 is an unknown quantity at this point
Front Brakes
When I am going 45 mph or higher there is a thumping coming front of the car.
Is it my rotors or my pads.....
And if so is it under warranty for a lease?
Please get back to me
Thanks
Old Jul 17, 2003
triumph439's Avatar
i got 17,000 on it and its not a screeching, definetly a sort of knocking
What you think?
Old Jul 17, 2003
triumph439's Avatar
you think honda will replace it under warranty casue i think it is covered under the lease....but not sure what you think
Old Jul 18, 2003
65Coronet440's Avatar
65Coronet440 is an unknown quantity at this point
You sure it's not something with your tires? Might be out of balance or might have picked up a rock or a nail or something too.
Jordan
Old Jul 18, 2003
slystad810's Avatar
Originally posted by NeonImpact
do you have factory 3 years, 36,000 mile warranty or extended warranty??
if so, take that thing there ASAP!
Brakes are considered a wear item and aren't covered under most warranties.
Is it only when you hit the brakes or all the time?
If it is only when you hit the brakes, you probably need new rotors. If its all the time, your tires are probably out of balance.
Old Jul 19, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Yeah like above, does your steering wheel shake, or your brake pedal vibrate, when you brake? If yes, you've most likely got warped rotors.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
rhvic
May 22, 2015 03:06 PM
bsmiley
Apr 27, 2015 01:27 PM
