Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
2024 Civic Sport Touring Hatchback - Tires/Wheels [solved]
Old Mar 26, 2025
Euwell's Avatar
Euwell is an unknown quantity at this point
My hatchback runs 235/40R18 tires. Potholes and curbs are a constant danger for wheel damage.......and the tires are extremely noisy. Considering changing to 235/45R18 tires, but not sure I'd have sufficient room. Anyone have any thoughts on this tire size change? Thanks
Old Mar 26, 2025
re: 2024 Civic Sport Touring Hatchback - Tires/Wheels [solved]
If you want more sidewall, consider going 17s or even down to 16s. Some sedan models came with 215/50-17's and some with 215/55-16's, and if they 11thgens are as similar between body styles like the 10thgens were, you shouldn't have any issues fitting those.
215/50-17s would give you a +.5% speedometer error (negligible, but actual speed would be higher than indicated)
215/55-16 would give you a -.5% speedometer error (also negligible, actual speed lower than indicated)
The 234/45-18's you're looking at would give you a +3.7% speedometer error. I personally like to stick to ±1.5% or less (of course, the closer to 0% the better) when I shop around for different than OEM tire sizes, then compare that calculated tire size to readily available options.
Old Mar 27, 2025
Euwell's Avatar
Great information, I'd not even thought of speedometer error. My biggest concern was (is) wheel damage due to the low profile tires. Most everything I see on the road now a days are low profile......maybe I'm just getting too old to deal with the newer fads? Thank you for the advise. Lee
Old Mar 27, 2025
https://www.wheel-size.com/calc/
This is the site I use to see all differences between tire sizes I'm comparing. Most people back in the day didn't give a crap about speedo error, just that they wanted bigger rims and rubberband low profile tires. When I was researching my first wheel upgrade, the concept of speedometer error came into play, and became a big part of what I look at when I want to change tire sizes or profiles. Another thing indirectly affected by it is your odometer, since erroneous speed indication would output different travel distances
Bearingman
Mar 28, 2025 01:03 PM
Honda1948
Mar 26, 2025 03:39 PM
bertsirkin
General 11th Gen
Sep 16, 2024 01:31 PM
thewal
Exterior
Oct 23, 2023 09:42 AM
Zakb
Wheels and Tires
Oct 21, 2022 06:47 AM
