Customize your car Post here for any custom modifications you want to to to your car!
Adding Power Windows to a 2004 Honda Civic DX
Old Sep 5, 2022
gatrhumpy1's Avatar
gatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of light
Alright folks! I got the mod bug again!
From my previous threads, I have added cruise control and working power mirrors on my newly painted 2004 Honda Civic VP.
I want to now add power windows.
I have a shopping list of everything I need, at least so far.
What I would like to know, before I go to the junk yard on Friday or Saturday, is on the following wiring diagram, are the 2 YEL/RED wires, the 2 YEL/BLU wires, and the WHT/BLK, GTN/BLK, and BLK wires on the front or the back of the MICU/fuse panel?
What is weird is that even on the VP/DX sedans, it still has the four 20A fuses for the window regulators on the under-dash fuse box.
Follow along as I attempt this mod!!!
Old Sep 5, 2022
Re: Adding Power Windows to a 2004 Honda Civic DX
plus the doors interior panels?
manual windows have the openings for the cranking levers
while in there, see if you find an EX and see if there is a good drivers' seat.
Arm rest, lumbar adjustment are good
Old Sep 5, 2022
gatrhumpy1's Avatar
The EXs have manual lumbar support on the sedans? I did not know that!
I don't necessarily plan to replace the door panels unless I need to. Apparently the driver's front door grip is different, so I will need at least front driver's door grip trim cover, the driver's side front door grip master switch cover, and the grip itself, along with the master window switch. Depending on mounting locations for the driver's side door grip, I might need another entire interior door panel.
Old Sep 5, 2022
Colin42's Avatar
You'll want the door panels, it will look terrible otherwise.
and you should be able to look at your own car and determine where the wires are.
gatrhumpy1
May 19, 2022 08:13 PM
gatrhumpy1
Customize your car
Apr 16, 2022 09:45 AM
CIVICGUY780
Jan 7, 2014 02:04 PM
miggitymark
Aug 24, 2010 10:54 AM
Supra554
Oct 17, 2007 10:40 AM
