Air Conditioning Post issues about air conditioning here
A/C clutch not working
Old Jul 21, 2023
Duke71790's Avatar
Duke71790 is an unknown quantity at this point
Need some help troubleshooting my A/C clutch,
I recently was driving home from work this week and my A/C started blowing hot air. Got home and started tinkering. My fans kick on but the A/C clutch doesn't engage.
I checked my fuse and it was not blown. I tested the relay by swapping it with a known good relay and still had the same issue. I pressed on the low side valve and freon shot out. I don't have any gauges but I am pretty sure there is plenty of freon in the system.
After finding a video on YouTube, I learned that you can run a check on the climate control module by holding down a couple of buttons and switch the keys on. After doing so it throughs a fault code. The fault light blinked four times and from what I gather, it is an open circuit fault.
I have had the A/c blow hot air in the past but I fixed it by replacing a relay. I have also had the blower kick off randomly and be driving down the road and it kick back one. It will also stick sometimes when I try to change it from one setting to another.
Any thoughts?
I have a 2009 Honda Civic LX
Old Jul 21, 2023
Colin42's Avatar
Re: A/C clutch not working
Measure the resistance of the clutch coil. Or try powering it directly with 12v and see if it engages
civicphil
Air Conditioning
Oct 11, 2016 10:01 AM
z28ls1
Air Conditioning
105
Sep 29, 2016 05:52 PM
mjdiaz89
Jun 21, 2016 09:26 PM
dinsum
May 28, 2015 09:30 PM
fabfive16
May 3, 2015 09:26 PM
