Air Conditioning Post issues about air conditioning here
A/C compressor intermittent—relay swap didn't fix.
Old Jun 21, 2022
civicownerky's Avatar
civicownerky is an unknown quantity at this point
A/C intermittently works, usually at startup. Then cuts out and blows warm/hot air (depending on outside temp and engine temp). When it's blowing warm, the compressor is not engaged. Replaced the fuses and compressor relay switch. Compressor still cuts out and the system blows warm air.
I did have the system recharged at Valvoline two weeks ago. No change.
What's the next step here? I don't have a lot of electrical know-how or tools, but I'd like to avoid an expensive trip to the dealer.
Old Jun 21, 2022
BrotatoChip's Avatar
Super Moderator
Re: A/C compressor intermittent—relay swap didn't fix.
Could be the compressor clutch. It wears down and eventually begins to slip, this generates heat. After a few minutes it will get hot enough to trip the thermal switch to prevent damage. A/C will begin working again after the compressor has cooled down.
Old Jun 21, 2022
Gotcha. That sounds like a new compressor.
Old Jun 21, 2022
Colin42's Avatar
You can replace the clutch and coil without replacing the compressor. Potentially you might just need to take a shim out. The system doesn't need to be evacuated.
check on rockauto. I did this on my 2000 last week.
Ohmster
Air Conditioning
May 23, 2021 08:10 AM
M240B
Air Conditioning
Jun 26, 2019 09:57 AM
Timbogates
Air Conditioning
Aug 19, 2018 04:34 PM
neocivic01
Jun 1, 2007 09:11 PM
black01civic
Aug 31, 2005 03:59 PM
