Air Conditioning Post issues about air conditioning here
2014 civic ex AC noise in low
Old Nov 1, 2020
Ivaan Garciia's Avatar
Ivaan Garciia is an unknown quantity at this point
Exclamation 2014 civic ex AC noise in low
Hello friends,
Today I was driving to my house and I turn A/C on, it is working fine but when I hit in low start to do a noise like this:
Any of you guys have and idea what could it be, and how to solve it?
I can say that the AC accomplish its function but the issue is that noise like a stuck fan
Kind regards,
Old Nov 1, 2020
Re: 2014 civic ex AC noise in low
You moved the temperature **** so check out the servo (hondas parts catalog calls it 'motor assy, air mix') that operates the blend door on the HVAC housing.
Gotta be making the noise while you are looking for it in order to find it, right?
Get a flashlight and follow the noise to its source.
drivers floor area stick your head up under the dash .......look up above where the drivers right foot and knee would be...higher than the gas pedal....
Sounds like you should be able to feel the vibrations from the pop with your fingers.....
find the servo, unplug the wire connector and the noise will quit if you got the correct unit unplugged.
Old Nov 7, 2020
I'll take a look to that air mix motor.
Jay213
General
Jan 6, 2020 11:50 AM
Peege777
Air Conditioning
Oct 10, 2019 05:32 PM
hiac
Mar 20, 2017 01:16 PM
bluestreak14
Jan 31, 2011 11:06 PM
Tbag
May 10, 2005 02:02 PM
