Air Conditioning Post issues about air conditioning here
New A/C clutch not engaging 2007 Honda Civic ex
Old Aug 20, 2019
Rob Taylor's Avatar
Rob Taylor is an unknown quantity at this point
A few weeks ago my ac in my car started blowing warm. I noticed the radiator fans still came on but the clutch on my ac wasn't engaging. Just in case I replaced the AC relay. I also ordered a new an clutch and installed it. After installing, it started blowing cold again for a good 40 min then stopped engaging again. I can't get it to come back on, even after tapping it with a wrench.
Any ideas what else it could be?
Old Aug 20, 2019
Wankenstein's Avatar
Re: New A/C clutch not engaging 2007 Honda Civic ex
Just tap it in...tappitty, tap,tap.
With engine running and the a/c set to "on" use a piece of 1"x 1" wood or similar to tap on the a/c clutch to see if it closes the air gap (between clutch and coil) to hopefully cause it to engage. If that's the issue the air-gap needs to be tightened back to spec.
Too much or too little freon can cause the compressor to not to engage as well. Use proper HVAC gauges to check and not those shitty freon cans with a gauge sold in auto parts stores.
Old Aug 20, 2019
Rob Taylor's Avatar
I gapped it to spec using a feeler gauge. And I've tried telling with a wrench while it's running. I can check it though
Old Aug 20, 2019
I should improve my reading comprehension...you already tried tapping it (first post).
I had a similar issue with an '07 Mazda 3 and it turned out to be (IIRC) the high side expansion valve. I'm not that skilled with HVAC and that was a local mechanic who found and replaced the expansion valve.
jkirk454
Air Conditioning
Feb 17, 2019 08:33 AM
stevenpsu
Air Conditioning
Jun 20, 2018 07:46 AM
kkiley
Mar 30, 2017 06:43 PM
JJ291
Jan 23, 2016 11:28 AM
chadds
Sep 9, 2015 05:26 AM
