Air Conditioning Post issues about air conditioning here
2008 Civic AC not always turning on
Old May 15, 2019
Jose Contreras's Avatar
Jose Contreras is an unknown quantity at this point
I have a 2008 Civic LX. The AC will not always turn on. Sometimes it turns on just fine. Other times it won’t turn on at all or start working all of a sudden while I’m driving. It doesn’t matter what setting the fan speed or temp setting it’s at or if it’s cold or warm outside. I checked the relay, replaced the blower resistor and the blower motor itself, but no luck. Any advice would be greatly appreciated.
Old May 15, 2019
Colin42's Avatar
Re: 2008 Civic AC not always turning on
Originally Posted by Colin42
air gap on the compressor clutch is probably too big.
free fix is to remove a shim from the clutch.
this has been covered countless times if you want to search for more info
​​​Look into this
Old May 15, 2019
How did you check this?
Relay problems are quite common, but not the only possible problem.
Old May 16, 2019
I swapped it with another identical relay switch. Nothing changed.
Caroldell1
Air Conditioning
Aug 1, 2019 02:26 PM
BROKE_BOI19
Nov 25, 2018 05:05 PM
danielrs
15
Apr 23, 2018 03:46 PM
Shannon233001
Aug 7, 2011 09:10 AM
MRB068
Jul 23, 2004 07:12 PM
