Regular Maintenance Post Questions/Information about Regular Maintenance here
first car tune up. Help a beginner honda lover
Old Apr 11, 2023
ImCisco's Avatar
ImCisco is an unknown quantity at this point
Question first car tune up. Help a beginner honda lover
hello, i bought myself my fist civic, is a 97 civic ex, i know nothing about cars, just that i really like 6th generation civics. i was wondering if any could tell me what do fix or change in the car, i already know that i need to change the oil and filter obviously and spark plugs, any other recommendations to make the car running smooth and perfect for couple more years engine area? car has a little over 150k miles. "automatic" thank you.
Last edited by ImCisco; Apr 11, 2023 at 06:46 PM. Reason: forgot to say thanks on post
Old Apr 12, 2023
Colin42's Avatar
Re: first car tune up. Help a beginner honda lover
Service all the fluids, make sure to use the correct fluid. Air filter and fuel filter as well.
Old Apr 12, 2023
BrotatoChip's Avatar
Super Moderator
Any record of the timing belt being done?
Old Apr 13, 2023
Wankenstein's Avatar
No need to change spark plugs if there isn't a misfire. However, if you do make sure to purchase NGK brand because they are the OEM (Original Equipment Manufacturer). These engines are particular about replacement parts in order to function properly.
In conjunction with what Colin and B-chip posted, if you don't have service records or the previous owner didn't specify to you when the last timing belt change was, when fluids (coolant, oil, power steering fluid, automatic transmission fluid (if not manual transmission), brake fluid were charged then ideally it's best to do those items for the maintenance of your car.
Especially the timing belt because they do wear down and if it snaps it could potentially harm the engine by bending intake/exhaust vales in the cylinder head on these "interference" engines.
greatguy49
16
Oct 22, 2015 06:51 PM
Litos Way
17
Jan 28, 2015 12:18 PM
plainzwalker
Buy, Sell, & Trade - Archive
May 22, 2006 01:40 AM
MiloBram
Feb 22, 2006 04:26 PM
2k1civic
Jan 10, 2004 02:33 PM
