Regular Maintenance Post Questions/Information about Regular Maintenance here
Advice on what tools to buy for basic maintenance?
Old Mar 1, 2014
jrnevada's Avatar
jrnevada is an unknown quantity at this point
I am not really handy with cars but not afraid to watch youtube and perform some basic repairs and maintenance.
I have a 04 Honda Civic Ex. Can someone recommend a tool "kit" or list what are some of the basic tools I'll need to some basic work?
Thanks in advance
Also, any good repair book(s) that covers this Civic?
Thanks again
Old Mar 1, 2014
GolNat's Avatar
Prelude Owner
Re: Advice on what tools to buy for basic maintenance?
A shop manual is the best book for working on the car:
http://www.ebay.com/itm/like/400600100651?lpid=82
A Haynes manual is also good and cheaper.
I started out with a 150 piece Craftsman mechanic tool set. It had all your standard tools that you need. I wouldn't cheap out on tools either.
Old Mar 1, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
+1K on factory service manuals. For domestics they tend to be a lot harder to understand and often have the worst way to do a proc... but for JM imports and esp Honda, this is the only book you'll need. If not possible, Haynes or Chilton, probably both, if you can't swing a bill for the FSM...
As a former pro Honda powersports tech, if you're going to do most of the DIY stuff possible in your garage, this is a good place to start:
-- Safety glasses & at least some thick shop nitrile gloves. Solvents hurt your liver and pancreas eventually (had to leave wrenching due to it), plus greasy fingernails tend to kibosh date night action.
-- Craftsman metric sockets & ratchets (3/8" is fine for most jobs except for situs I'll cover a bit further down). Craftsman's pro hand tools tend to be nicer to work with, but their cheapies will do the job... they've come a long way since the '90s when I started...
49-pc Easy-Read Mech Tool Set - $50
58-pc Max Axess - $86
-- Craftsman wrenches. Used to be wretched to use daily for me, but they've improved their basic ones a lot since the '90s... and their Pro line is only the tiniest margin behind Snap-Ons in feel and comfort to use. Combos in 7mm, 8mm, 9mm, 10mm, 12mm, 14mm, 17mm, and 19mm is plenty to get you started (may want 13mm, 15mm and maybe 18mm if you also want to wrench on SAE stuff). I found double-offset box-ends in 8mm/10mm and 12mm/14mm to be very handy too. If you can afford racheting box-ends, get them in whatever sizes you use the most -- they'll see duty. I think Craftsman makes a set of metric rachet box/open combos, that'd be trick to have...
-- Decent multimeter. Making some test wires with blade connector ends, and either buying or making jumper wires will help a lot with electrical diag.
-- 1/2" breaker bar and 1/2" rachet. Doesn't need to be Craftsman, Harbor Freight makes burly-enough 1/2" stuff for the things 1/2" tools tend to be used for... and a lot cheaper. You'll need the 1/2" socket size for your axle nuts as well...
-- 36" cut conduit pipe for a breaker extension (you can use whatever you can find of course... a motorcycle fork tube works great too)
-- Craftsman clicker torque wrench. Not ridonkulous-expensive like my Snappie Golds, but not one-use, either. About $40 - $50 for a 25 - 250 lb/ft one, which IINM will cover 90% of Honda auto fasteners
-- Nice pry bar -- you'll see, they're the difference between hurling a toolbox across the garage, and a snag-free service (axle swap esp)
-- And a basic box to carry it all in. I like the rolling kind... Dewalt and Stanley (Fat Max) make some good ones you can grow into before a real rollaway is needed...
-- Drip tray, $10 at Wally World. Not only catches and reveals drips, but also allows you to hear if something hits the floor, like a vital fastener.
Magnet on a stick Magnet on a stick
. See above...
-- Or better yet get something that magnetizes your tools.
-- Jackstands. Get 4, they're pretty cheap insurance (plus there are a few jobs where you need the car level but off the wheels). Never work under an unchocked car supported only by a jack, esp a hydro one, unless you like eating Propofol and breathing through a tube. You can chock with some lumber, though I prefer purpose-made chocks.
That's basics I can think of off the top; board will surely have more Honda-car-centric suggestions. Have fun!
Old Mar 1, 2014
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
+1 on the Haynes manual!
a good craftsman set is key. All Craftsman parts have a lifetime warranty. I have a small kit like this that gets me by for most stuff:
http://www.sears.com/craftsman-58-pc...8000P?prdNo=21
Then you can buy whatever odd parts you need like extensions and a set of deep sockets.
This is a pretty stout kit that comes with probably everything you need expect maybe a 10" extension:
http://www.sears.com/craftsman-165-p...&blockType=G68
Also a quality speed jack and jack stands, or at least ramps for oil changes would be a good investment too.
Old Mar 2, 2014
jrnevada's Avatar
What would you consider a quality speed jack?
Old Mar 2, 2014
GolNat's Avatar
Prelude Owner
I have a craftsman jack. I only use it if I need to remove a wheel, if I don't then I use ramps. If you have the money I would get a jack and ramps but just a jack is all you need.
Old Mar 2, 2014
mikey1's Avatar
i think the absolute minimum would be.....
- large metric socket set (200+ pieces)
- metric wrenches 6mm to 19mm
- screwdriver set
- haynes or equivalent manual
- jack stands and jack
- torque wrench
- pliers, needlenose, vise grips also come in handy
- 1/2 inch drive breaker bar with pipe extension
i bought a 6 foot by 1 inch cast iron sprinkler pipe, i slide it over the breaker bar to remove tight bolts, it works great
Old Mar 2, 2014
200 pieces? Jesus Christ. I doubt you'd end up using half of that ****, and you'd be dropping hella money on that thing. I think I can take apart my car with maybe 10 sockets, an array of extensions, and a socket wrench.
absolute basic tools I use to work on my car:
-8, 10, 12, 13, 14, 15, 17, 19mm sockets (a 12 point-12mm is necessary for removing the head, and I forgot what size the valve lash adjustment nuts are). You may need a 21mm somewhere.. Also, a 30mm (or was it 32?) if I wanna pull my wheel hubs
-The array of extensions, as mentioned above
-combo wrench set
-crank pulley holding tool if I need to pull the timing belt
-I have a set of impact sockets to make my life easier, but they're not absolutely necessary. Well, some may be, just to be rugged enough to be able to use them with...
-a 1/2" drive breaker bar. Maybe a length of galvanized pipe that can fit over the end of it for especially troublesome bolts
-a torque wrench or two. I have two. Both Craftsman Microtork, one is a 1/2" drive 20-150 ft-lb, the other is a 3/8" drive 20-250 in-lb. I was a nuclear power plant mechanic in the Navy, and they drilled it into our heads of how to choose a proper torque wrench (for maximum accuracy, your desired torque spec must fall between 20-90% of the range of the torque wrench you're using). The in-lb one I use for spark plugs and valve lash adjustment. I'll also note that I used a crap $20 torque wrench from Harbor Freight before that. The clicker part failed and I ended up overtorquing a bolt for the fuel rail, and it stripped it out.
-A few different kinds of pliers, crescent wrenches, vice grips, etc. I've found these especially helpful
-Screw drivers are a must, as well. Both flat and phillips head. I forgot if you need torx drivers, though. I'd grab those as you need them. If you need to remove your rotors, then get some hefty ones that you can put on a socket wrench.
-jack and jack stands, at least 2 stands (4 if you want your car completely suspended off the ground for.. reasons..)
If you feel like delving into electical work/modifications, a decent soldering station isn't a bad idea. You can get that cheap at radio shack.
For emergency purposes, I keep a small metric socket set and a 12" extension in my car, one of those flip-flop 6-in-1 screwdivers, as well as a 19mm deep socket and a breaker bar in case something happens on the road. I can almost take apart the car with my emergency kit alone.
Also, be careful with that breaker bar. Grab some liquid wrench if you encounter a troublesome bolt. You don't wanna end up stripping the head of a big *** bolt by using excessive torque. On the flip side, you don't want to snap or strip out a bolt by overtorque. Use anti-seize for things you don't want to seize up, and use proper torque to ensure it stays on. For things like sensors that can cause massive heartache and headaches, use some blue locktite. I had an incident where my TDC sensor decided to commit suicide and take the timing belt with it.
Old Mar 2, 2014
Old Mar 2, 2014
jrnevada's Avatar
What are some differences between the Haynes book and the one that comes from Honda?
Old Mar 2, 2014
Honda one will be more in depth. I've had no issues using a Haynes manual. Anything more in depth I need, I just use the forums.
Old Mar 3, 2014
kinakoes2's Avatar
You can get a PDF version of a 7th-gen manual on ebay for what, $5 - $10? Well worth it, and no big-*** book to tote around. You can even store them on an SD card on your smartphone like my past car & bike FSMs, so they're always on-hand.
When I grad from bike tech school in '97, I too wanted all these shiny neato tools. And as riceboy mentioned... when it came time to hang up my helmet, there were some that never got touched -- not even once. And my stocked rollaway was a $7000 Snap-On one (got it for 50% off though, ah the good ol' days...).
Point is... you'll figure out what you'll need as you go. I know morons who buy nothing but Snap-On, even for stuff you'll just beat up. I have no such money tree so my box contains all kinds of tools -- tools that do the job well are all that count. Yup, lotsa Harbor Freight too... and made 70 - 80 hrs flat rate a week, no problem.
Old Mar 4, 2014
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
Don't spend money on a shop manual or a Haynes/Chilton. You can get the shop manual for free right here on this forum!
https://www.civicforums.com/forums/1...e-updated.html
I downloaded this to a USB drive, and take it with me everywhere. Works great!
Old Mar 4, 2014
jrnevada's Avatar
I saw that and every link I clicked on no longer existed. I did not go through every page but enough and thought the thread just went dead. Do you have a direct link to the download?
Old Jan 5, 2021
reedcooper's Avatar
Automotive Blogger
reedcooper is an unknown quantity at this point
I'm no handyman, but I ascribe to the same philosophy with tools as I do with kitchen knives: quality, not quantity. There are obvious basics you'll need, but I would avoid large "tool sets" with a variety of tools that you may or may not need. I would buy the highest quality of the ones I did know I was going to use. For instance, your tool needs will very much depend on what sort of car work you plan on doing, or house repairs. If you're changing your oil, you might find a socket that fits the oil filter useful. Changing spark plugs might require another specialty socket. If you're doing work with wires you might want a pair of electrical pliers (I'm sure these have a real name). Perhaps a set of nut drivers will be useful for automotive work, or maybe you won't need those at all.
I think everyone needs:
-One or two "normal" sized screw drivers (philips and flat)
-A set of mini screw drivers (always useful!)
-Probably a torx set, for your spy dies
-A pair of needle-nosed pliers
-A decent hammer
-A non-marring mallet
-A Smalish crescent wrench
-You'll probably want a socket wrench set for the automotive work, but the sizes/units will be dictated by the kind of work and make of car
From there I'd add as the tasks dictate. I've had fine luck with the "Husky" socket wrench set I have, I don't think you need to go snap on if you're not an actual tradesman.
However, I have found this tools list review informative and useful. Hope it will help you to get proper idea about some necessary tools for beginner.
stolenrange
General 8th & 9th Gen
16
Jun 19, 2021 06:29 PM
Mig21
Mechanical Problems/Vehicle Issues & Fix-It
20
Feb 22, 2020 11:19 PM
Tony123
General 10th Gen
Jul 27, 2018 06:28 AM
dsm482
Feb 27, 2018 11:37 PM
soulja a
Sep 6, 2013 09:30 PM
