Regular Maintenance Post Questions/Information about Regular Maintenance here
transmission fluid
Old Apr 29, 2022
einzigal's Avatar
einzigal is an unknown quantity at this point
transmission fluid
It wouldn't hurt to change but if it looks clean, I would probably leave it until you put some more miles on it.
Do you suggest the same course of action for a 2009 LX with 317K, too? That's what I have and also have the understanding that the transmissions of super high mileage vehicles work better with the additional friction provided by the impurities of old fluid and might actually start slipping once it's changed...
Old May 2, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Transmission fluid
When was the last time the ATF had a drain and fill of Honda DW-1 in that 317K interval? Recommended every 30K miles to have a drain and fill.
Old May 2, 2022
einzigal's Avatar
Good possibility it's been 200k ago, unfortunately. I'm also interested in changing the inline transmission fluid filter and would appreciate your input on that. I'm sure the filter has never been changed.
Old May 3, 2022
NDNV's Avatar
Since your Civic is a 2009, I would suggest you search the 8th gen Forum section for advice on this topic. It is risky changing ATF in a Honda trans that hasn't been changed regularly.
Old May 3, 2022
emich's Avatar
emich is an unknown quantity at this point
I did transmission fluid flush on my 2001 Civic close to 200k mi. I doubt there was any trans fluid change earlier. The fluid vas dirty. Also installed trans. inline filter. No change in driving after the flush. I don't know if the trans. inline filter have a bypass valve to let the fluid through when gets clogged.
Old May 4, 2022
einzigal's Avatar
Thanks for the info as that's encouraging! Do you remember what fluid you used?
Old May 4, 2022
einzigal's Avatar
Great advice, thanks!
Old May 4, 2022
emich's Avatar
It was synthetic suitable for Honda from Walmart (Red 5 or 4 qt. jar)
I am not planning to change it ever again on this car. It will last longer than the life of the car.
Old May 4, 2022
einzigal's Avatar
Thanks! Since my '09 has 317k this'll probably be it for mine too.
Kennykenny
Jul 25, 2016 07:12 AM
rhvic
Regular Maintenance
Nov 25, 2014 08:00 PM
combinatorix
15
Nov 5, 2011 12:05 AM
girouard
18
Jan 13, 2011 08:49 AM
scott37300
16
Dec 20, 2010 07:28 PM
