General Post General Issues questions here that does not fit other sections
Hey guys I have a problem, I have a 13 Civic that I can't turn traction control off b
Old Dec 29, 2025
Foreverzero89's Avatar
Foreverzero89 is an unknown quantity at this point
So I recently swapped on my winter tires, which do not have the DPMS sensors and apparently you can't turn the tractor control off if you don't have those. I thought about what if I just pulled the fuse for traction control, but you can't do that either because it's linked to other main fuses which you can't start the car without! Any help would be appreciated, because if I get stuck you can't do the rocking back and forth technique if you traction control just keeps engaging every time!
Thanks
Old Dec 29, 2025
Colin42's Avatar
Re: Hey guys I have a problem, I have a 13 Civic that I can't turn traction control o
Guess you're getting sensors
Old Dec 29, 2025
I guess, I keep getting conflicting focking evidence that the car doesn't have sensors and it uses some other way to determine that or that they does have sensors I don't focking know, the only thing I do know is that if you try to pull the fuse for the tpms, that doesn't do ****, and if you do pull the fuse for the traction control system it disables power steering and like two other feckng systems that's not labeled in the goddamn manual so it's goddamn bullshit unless you want to just deal without power steering and my wife can't do that it's f u c k ing bullshit Honda could kiss my whole f u c k ing ***
Old Dec 30, 2025
Colin42's Avatar
Buddy it's just tire sensors.
My current car disables the cruise control if the check engine light comes on. Some engineer in their infinite wisdom decided this was a good idea. It's annoying sure but without reprogramming the computer there's nothing you can do.
yingjai
Electronics
32
Feb 22, 2021 08:13 AM
Exilko
Air Conditioning
Aug 9, 2019 05:21 PM
Mike4831
Oct 12, 2007 11:09 PM
Supermanrider
18
May 4, 2005 11:20 PM
obtix
May 8, 2003 12:04 PM
