General Post General Issues questions here that does not fit other sections
Honda '13 Horn
Old Oct 18, 2019
guru1214's Avatar
guru1214 is an unknown quantity at this point
Exclamation Honda '13 Horn
I am having difficulty diagnosing why my horn does not work.
When pressing the horn there is a clicking sound under the hood on the same side as the fuse box.
I have changed fuses, checked relay, and even taken off the bumper and changed the horn.
What are the recommended next steps?
Thanks!
Old Oct 18, 2019
Re: Honda '13 Horn
If you're hearing a click near the fuse box, sounds like the fuse is good. Time to check the horn itself. Connect the pins directly to 12VDC to see if it beeps at you. If it doesn't, you found the culprit. If it does, there's some wiring issues -- could be connectors, could be wiring damage. Check components first because they're easier to fix.
DeX
Sep 12, 2013 01:10 PM
bubbles1980
May 6, 2012 04:09 PM
TransformedBG
Buy, Sell, & Trade - Archive
Sep 5, 2007 11:58 PM
2k1Civic04
Nov 22, 2002 08:55 AM
LuvDatCivic
Sep 27, 2002 01:16 PM
