Re: B18c GSR swap
Re: B18c GSR swap
So it looks like I need to use a D series engine. I see they were made until 2000? Now looking for a D16 to replace my D15. Adding 50% more hp will definitely help at altitude and climbing hills.
Re: B18c GSR swap
Most will require, at the very least, the corresponding ECU and wiring harness.
Cheapest and easiest swap *worth* doing is probably a B18B1 from an Integra.
Re: B18c GSR swap
I thought the Acura engines needed Acura transaxles, too? I have a low final drive like a VX (3.25) and want to keep that, since I do a lot of long distance driving. If a B18B1 will bolt up, that would be terrific.Like I said before, going from 87 to 125 hp is plenty for my use. I presumed that I would need the corresponding ECU, thanks for verifying that.
Re: B18c GSR swap
Ninjarooster
Oct 27, 2016 10:18 PM
R Sporty
Feb 7, 2010 08:56 PM
honda92hatch
May 1, 2009 11:11 PM
