Air Conditioning Post issues with air conditioning here
Heating issue
Old Nov 13, 2025
Carrs's Avatar
Carrs is an unknown quantity at this point
Heating issue
Hello , my heat only works when im actively driving. Other than that it doesn’t work but ac works fine and air always blows . My coolant levels are good i did bleed it to make sure there is no air bubble . I did a heater core flush nothing came out . I also checked the valve and it works fine . Im not sure what else it could be can i please get help its not my thermostat being stuck open as well
Old Nov 14, 2025
Colin42's Avatar
Re: Heating issue
Thermostat might be stuck open
Old Nov 14, 2025
Carrs's Avatar
Re: Heating issue
i checked that as well its not it
Old Nov 20, 2025
FRSam's Avatar
Click Here
Re: Heating issue
If the thermostat is good, the coolant level is good, and there's no air in the system, and there's no restriction in the heater core (but it sounds like there may be), the only other thing that affects coolant circulation under load is the water pump. It's possible it's beginning to fail.
rtread16
Oct 27, 2023 06:31 AM
ernest64xp
Dec 8, 2020 11:46 AM
alex_nyc
Jan 17, 2015 03:35 PM
RoccoCroce
16
Apr 14, 2014 08:42 AM
CivicRen
Oct 18, 2011 09:21 PM
