Air Conditioning Post issues with air conditioning here
No airflow from center vents
Old Oct 30, 2023
Dummy's Avatar
Dummy is an unknown quantity at this point
I have an 04 civic ex coupe
All the vents in my car work except the 2 that are directly above the radio (I circled the 2 vents in the photo)
The heat works, the a/c works, the defrost works, the only issue my a/c system has it that the 2 vents directly above the radio do not blow air out of them
I am going to buy a door mode actuator and replace it with my cousin, my question is does anyone know of anything else I should check first before replacing the door mode actuator?
The 2 vents right above the radio do not blow air (I circled the 2 vents)
Old Oct 31, 2023
BrotatoChip's Avatar
Super Moderator
Re: No airflow from center vents
Do all other modes work correctly? If you set it to feet, does it blow out the bottom vents?
learnfpga
Dec 3, 2007 01:52 PM
topnotch7gen
Jun 16, 2007 10:59 AM
dups
18
Jan 2, 2003 10:01 PM
MadSpeed
Aug 16, 2002 11:19 PM
