A/C too cold?
Old Aug 8, 2002
MadSpeed's Avatar
MadSpeed is an unknown quantity at this point
A/C too cold?
Last night me and my friend were riding around in my 7th gen civic and the air vents seem to be producing a lot of percipitation. Eventually the radio quit working but then started working two hours after i turned my a/c off....could the water have caused my radio to stop working? And are 7th gens suppose to be producing soo much percipitation? (It runs down the dash) Mabe its the hot humid weather down here in south texas.
Any help on this problem will be appreciated.
Old Aug 9, 2002
solar's Avatar
solar is an unknown quantity at this point
Do you have the windows down or cracked or the sunroof open with the A/C on? If not use the "recirculate" button because whats happening is that the outside air is so humid your A/C system is working to pull the humidity out of the air. Thats all a A/C unit does is remove humidity out of the air, once the humidity is removed from the inside of the car that shouldn't happen, so you need to stop the outside humid air from entering the car by having the windows rolled up and the recirculate button on.
This is the only thing thats causing your problem, as far as your radio goes, unless condensation is building up under the dash and shorting out your radio, I don't know.
Old Aug 10, 2002
MadSpeed's Avatar
I usually have the moonroof open.....the reason i keep the a/c on no matter if the windows are up or down is because the factory radio has a problem with heating up my cd's and not being able to play them when they get hot. Thank you for the info.
Old Aug 15, 2002
xylamic's Avatar
xylamic is an unknown quantity at this point
that is not a common thing, i live in houston and me and 3 or my friends have civics.....no one has had that happen.....take it to the dealer
Old Aug 15, 2002
solar's Avatar
Quote
[hr]Originally posted by: xylamic
that is not a common thing, i live in houston and me and 3 or my friends have civics.....no one has had that happen.....take it to the dealer[hr]
He doesn't have to take it to the dealer.
Its because he had the sunroof open, if its a real humid night and you have the A/C blowing full blast with the recirculate button off its going to happen. It normally only happens at night and the conditions have to be right. Read the above posts.
Old Aug 15, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
ya the only time i see/feel it is at night, weird delemma you have there..
Old Aug 16, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
ok, 1, its a waste to have your ac on and have the windows open, youre wasting the extra gas it takes to run the as compressor, plus youre loosing that power.
2. i pesonally tink the ac should be cooler, i find it takes a good 10 mins to get COOL, and never really gets cold. ive measured a 92 or so taurus (in auto shop @ a VoTech) at about 52 degrees, i think mine only gets down to about 70. but anyway.
3, im glad i dont live in that area of the country, im in pa an its hot enough up here.
just my $.02
Old Aug 16, 2002
solar's Avatar
Quote
[hr]Originally posted by: EternalVTEC
just my $.02[hr]
It really doesn't use more gas when you run the A/C with the windows open, because the system doesn't know that the windows are open, the A/C system seldom cycles even with the windows up because car systems are so inefficient. I live in Florida and in the fall it might be 80° outside but the humidity is really low so I'll drive with the A/C on with the sunroof open during the day. I've noticed no difference in fuel milage. Your right about the system not getting cold enough, its a big complaint on this site, but I find that after 10 minutes in 98° sunshine that the system is very cold. Black cars with dark interiors take a lot more BTU's for a A/C system to make the interior comfortable. Just my 2½¢
Old Aug 16, 2002
what i meant was that when the ac is on you usually need to apply more gas to get going, especially w/ stick. that uses more gas. and i still cant see the point in keeping the car vented while the ac is on. th only time i do that is when i first turn it on, that way the heat rises and escapes the car, then i seal'er up.
Old Aug 16, 2002
solar's Avatar
Quote
what i meant was that when the ac is on you usually need to apply more gas to get going, especially w/ stick. that uses more gas. and i still cant see the point in keeping the car vented while the ac is on. th only time i do that is when i first turn it on, that way the heat rises and escapes the car, then i seal'er up.[hr]
I don't notice any differnce with acceleration with the A/C on or off, the compressors that Honda uses are "low draw" compressors which probably explains why our A/C isn't very cold at first. Yah I know some people think I'm nuts running the A/C with the sunroof open, but on a nice fall day i like the sunroof open but its still to warm in the car without the A/C on, and I don't like to roll the windows down. Just babbling here I'm leaving work early and just killing the last 2 minutes.
Old Aug 16, 2002
jro's Avatar
jro
jro is an unknown quantity at this point
i really don't notice that my car accelerates much slower, but i do notive a difference in shifting. when the a/c is on i find it harder to rev the engine freely. it seems that the engine is not as responsive i.e. when i have to blip the throttle on a downshift. i think that it's due to more driveline drag with the compressor engaged. i don't know that's my $.02. does anyone else notice this?
-jro
masongardner
Air Conditioning
21
Jun 29, 2019 05:10 PM
andyandyy
Aug 4, 2015 06:37 PM
Jul 14, 2015 03:39 PM
